Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Vista installation problem
Forum Windows Vista : Vista General Discussion - Vista installation problem
I'm trying to install vista on my computer,during the installation everything seems ok,but after the last restart,at first a black screen with Vista logo on top middle and some dots seems on display,then vista doesn't run..system is seems to be blocked..i tried lots of ways to install..different installation dvd's in to different harddrives..my system is completely new,my configuration is :
Intel Core2 Quad Q6600 2.4 Ghz
4x2 Gb DDr2 = 8 Gb Memory
400Gb WD Sata HDD 16Mb Cache
320Gb WD Sata HDD
160Gb WD Sata HDD
Gigabyte GA-P35C-DS3R Mainboard
M-Audio Audiophile 24/96 Sound Card
LG DVD-RW Optical Drive
Sparkle Calibre N-Vidia 8600 GT Graphics Adapter
On this configuration;Windows XP Pro runs well,but any versions of Vista doesn't run (32 or 64 bit,no makes difference)
I tried lots of way,but i don't have any opinion about it,do you have some advices..
Thank you very much
Sponsored Links
Use one DIMM RAM in slot one, not 8GB's to install an OS. The system doesn't have the MB/chipset drivers installed and you are trying to run 8 GBs of RAM on it. Use one DIMM in slot one. In BIOS set the memory voltage to specs. 2.0-2.1v for PC26400. Set the timings to 5-5-5-15. Load the OS and install the MB/chipset drivers and OS patches. THEN add the other 6 GBs of RAM and adjust accordingly.
Message edited by badge on 03-06-2008 at 12:24:57 AM
Reply to badge
Badge thank you very much for your help..i'll try that so quickly..i didnt think this way before,you should be right.thanks
Reply to gurcan59
- 0 +
im having this same problem with the ultimate 64 bit. i will try what badge said also
Reply to Dan_P
There are 1221 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
