Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Problems running 4gb and multiple hd
Forum Windows Vista : Vista General Discussion - Problems running 4gb and multiple hd
I recently installed Vista Ultimate 64 on my pc I built, but I'm having problems after the installitation with being able to use my extra 2 gb of ram or my Raid-0 config. Any help on why it won't load up when I connect the extra ram or the other hd's?
Sponsored Links
Some more information on your PC would help. So would some more information on what "won't load up" means.
Reply to dmroeder
Memory:
How about the BIOS? Is it showing 4GB? Some MB must enable something like "memory remapping".
http://support.microsoft.com/kb/929605
RAID:
Are you capable to see the option will booting to access your RAID menu?
We need more information.
Reply to loneeagle
Yes, the bios registers both the memory and I set the other hd's up in raid through the mb bios so they're both recognized by it. My setup is vista ultimate 64, 150gb hd, 2 250gb hd's, 4 (1x1)gb of ram, on a striker 2 formula board. Once I connect them though I just bluescreen and can't get past that unless I unhook them and run the system without. I had the bootmgr error while installing with all the hd's connected so i unhooked the 2 in raid, and i had heard not to install vista with more than 2 gb of ram so i didnt put that in either. Now that i have everything installed and have ran all the updates I still am having trouble with it.
Reply to T_Iz_Me
For the RAM, yes you must install with 2GB and install a patch.
http://support.microsoft.com/kb/929777/en-us
After you install the patch, must reboot to windows and shutdown to install rest of your ram.
For the RAID, may be related to ram problem. I would keep the raid but only 2gb of ram. Once all installed + Windows updates + patch, then 4GB.
Reply to loneeagle
There are 550 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
