Yes No
Ads
Tom's Hardware > Forum > Windows Vista > General Discussion > No audio device is installed (typical solutions don't work)
Forum Windows Vista : General Discussion No audio device is installed (typical solutions don't work)
hey all,
i've just about had it with this issue. i had audio working great, until i tried to install new creative drivers for my audigy SE (basically a live 24-bit..). anyway, after i installed those drivers, i realized i needed to delete a certain entry in a registry (forget which one :pfff: ). so next bootup, my problem began. vista claims that "no audio device is installed" in sound manager, although Device manager reports all as well :heink: . I decided to rule out a driver error, attempting to use my onboard audio (realtek azala audio ALC 889A). i made sure to go into safe mode, use driver cleaner pro, and delete all of my creative files. a strange thing i noticed is that the entry "sound blaster audigy" is still present in the "uninstall programs" app. anyway, the new device drivers installed successfully, and i'm sure of it after countless attempts. i'm not sure, but i think the problem is emerging from a missing codec/ some sort of missing media file from vista (i might have deleted an important file, too bad i can't recall which one i deleted :pfff: )
any help would be great :wahoo:
------------------------------ http://tinyurl.com/5mvund
E6300@3.2ghz 1.32v | Gigabyte P35-DS3R 1.0
4x1GB C5@900Mhz | 8800GT
Reply to monst0r
bump ..
by the way, a possible fix i was thinking of was if there's a way to restore vistas default codecs and audio properties somehow, without a clean install. if this problem isn't fixed this weekend, i guess ill just reinstall :(
Message edited by monst0r on 03-28-2008 at 08:09:51 PM
Reply to monst0r
- 0 +
well, problem solved with a reformat :pt1cable:
M$haft should really have a fix for that, its a really common problem (from an upgrade to sp1 or from xp..)
Reply to monst0r
- 0 +
Welcome to the wonderful world of owning a Creative sound card! While Creative loves to blame MS... it's usually their drivers that are the problem.
Reply to Zoron
- 0 +
while i agree to this, with the whole daniel_k incident, it's a problem with many different brands of sound cards. it must be something in vista's WDDM, but i really don't know. all i know is that it caused me to waste 10 hours of my life doing nothing :fou:
by the way, i'm sticking to onboard sound now, because of creative's lack of 5.1 support on audigy SEs/live24 bits.
Message edited by monst0r on 04-07-2008 at 12:25:24 AM
Reply to monst0r
Man, I personally probably won't buy creative anymore. Besides, why should I when my gigabyte board has HD sound outputs?
Reply to ohiou_grad_06
There are 2059 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I cannot get my external hard drive fully installed on vista
By nhasian, 1 day ago:
rather than fdisk it is recommended to use Disk Management. Create and format a hard...
Best offers
Top experts
