Turn off System Sounds
Forum Windows XP : Windows XP General Discussion - Turn off System Sounds
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Is there a simple way to turn off all those sounds that Windows XP generates
, from resuming from hibernation or standby, beeping, chirping, playing
chords that are supposed to tell me I just did something, etc? I found a
list of the system sounds it generates and it seems awfully tedious to have
to go throukgh the ocean of sounds, reset each to none, confirm that yes I
don't want to hear the sound, etc., and then save that arrangement with some
sort of name. But is there a simple way to kill all the souonds? I will be
using my laptop for courtroom work and such noises are an embarassing
distraction. However, I would still like to be able to use what sound there
might be with video clips, PowerPoint animation etc.
Sponsored Links
> Not being a a smart A## but turn the volume down all the way or if there is a speaker icon in the bottom right corner, double click it and mute everything. Otherwise, you need to access the control panel open sounds and select none for each event.
Reply to unrepper
You can stop all event sounds with a few clicks...
In the Control Panel, open Sounds and Audio Devices.
Click the Sounds tab.
Under Sound scheme, click the arrow at the right side of the list box.
Click No Sounds
Click [No] (if prompted to save current scheme)
Click [OK]
Austin M. Horst
Reply to Anonymous
It works! It seems I can indeed get rid of all those computer sounds yet
play vidoe/sound clips. And switch back to those sounds when they will not
distract a crowd!
"Austin M. Horst" <anonymous@microsoft.com> wrote in message
news:eZLm98TWFHA.1040@TK2MSFTNGP10.phx.gbl...
> Click No Sounds
> Click [OK]
> Austin M. Horst
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Turn off System Sounds
There are 1096 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
