Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Chkdsk found strange errors on C: (index entry and (MFT) bitmap)
Forum Windows XP : Windows XP General Discussion - Chkdsk found strange errors on C: (index entry and (MFT) bitmap)
While I was watching a video my pc froze, so i had to turn it off, when windows XP booted it ran a chkdsk on c: which reported the following errors.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
Index entry ntuser.dat.LOG of index $I30 in file 0x278c points to unused file 0x2858.
Deleting index entry ntuser.dat.LOG in index $I30 of file 10124.
Index entry NTUSER~1.LOG of index $I30 in file 0x278c points to unused file 0x2858.
Deleting index entry NTUSER~1.LOG in index $I30 of file 10124.
Index entry Windows of index $I30 in file 0x2813 points to unused file 0x2859.
Deleting index entry Windows in index $I30 of file 10259.
Cleaning up minor inconsistencies on the drive.
Cleaning up 626 unused index entries from index $SII of file 0x9.
Cleaning up 626 unused index entries from index $SDH of file 0x9.
Cleaning up 626 unused security descriptors.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
312560608 KB total disk space.
25112820 KB in 43616 files.
14112 KB in 4289 indexes.
0 KB in bad sectors.
124064 KB in use by the system.
65536 KB occupied by the log file.
287309612 KB available on disk.
4096 bytes in each allocation unit.
78140152 total allocation units on disk.
71827403 allocation units available on disk.
I'm running a
Athlon 64 x2 4800+
Gigabyte M52S-S3P
Asus GeForce 8600 GT (PASSIVE COOLING)
on Windows XP Sp2
What could of caused these errors?
Sponsored Links
A corruption in the file system or a failing hard drive.
Grumpy
Reply to Grumpy9117
There are 1355 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
