Hi there!
I am currently trying to find a suitable upgrade for my brother's graphics card. The fact that my family's computer is an old factory pre-built case, tends to complicate matters, though. Also, it has been five years since I ordered my own computer, and power requirements have shot through the roof in that time, if I understand correctly. In short, I feel like I am severely out of the loop in terms of pc development, and I would be grateful if some of you could help me out with this.
Now, my brother's old card is an ancient Radeon 9200 256 megs. This card folded, of course, when asked to run Splinter Cell: Chaos Theory. It was high time for a change, anyway. As the old computer only supports the AGP interface, I decided the Radeon x1950 PRO would be a good upgrade, as has decent performance and comes at an affordable price.
It turns out, however, that the built-in power supply was a bit on the low side. It is an FSP Group 280 watt PSU. The model no. is FSP280 - 60PNA - I (PF). According to the label, the 12V rail (which I gather is important) is charged with 16A. Now, my question is whether this PSU will be enough to power the X1950 PRO. I gathered from Tom's Hardware that it was less power consuming than earlier versions of the 19xx line. The other components it powers are as follows:
Intel Pentium 4 3,2 ghz, Northwood model.
1024 mb RAM - 2x 512 DDR.
1 hard drive of around 300 gb.
2 optical drives - 1 DVD ROM and 1 DVD RW.
1 card reader thingy.
4 USB drives.
It would be really nice to hear some opinions on this, as I frankly have very little compentence on this area myself. If more information is needed, feel free to ask. Thanks in advance!
4 USB drives.
