Quick question i've read a lot of people say to set the DRAM Frequency to DDR@ - 533 on a P5B Deluxe this will result in a 1:1 ratio with the fsb and the ram. my question is if the fsb is say 334mhz and the cpu multiplier is 9 to achieve a cpu speed of 3.0GHz that means that the memory will run at 334 mhz as well but my ram is ddr2 800 so it runs stock at 400 so the cpu is overclocked but the memory is underclocked right? is that going to hinder performace or should i go with a 400 fsb at a different mulitplier? Just asking because i've read that you can achieve lower vcores with smaller fsb's which should reduce temp. I just want to over clock my e6600 to 3GHz with a asus p5b deluxe wifi/ap and 2 gb (2x1gb) corsair xms2 ddr2-800 ram but achieve the best results with lowest temps thanks for the help!
