Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Battery problems in Notebook after installing Vista.
Forum Windows Vista : Vista General Discussion - Battery problems in Notebook after installing Vista.
I have a Sony Vaio. I recently installed Vista on it. And now whenever I close the lid, it does go to sleep but the battery still depletes. I tried looking into power settings but cant find whats the problem.
Thanks.
Sponsored Links
Check all of your device properties - make sure wifi and nic goes offline when using the battery, check their man. website for driver updates for Vista, etc. Also, try hibernate versus sleep and see how much of a difference it uses - sleep intentionally uses a small amount of power while hibernate uses zero.
Reply to pkellmey
thanks, I'll try hibernate.
Reply to feltadox1337
It worked after I set it on hibernate. I guess it was on hibernate before.
Thanks
- 0 +
Sleep mode still drains the battery because it still requires power. Hibernate doesn't require power, so it won't drain the battery.
------------------------------ Desktop: Windows 7 Professional 64-bit; Intel Q6600 CPU; E-VGA 780i SLI motherboard; E-VGA E-GeForce 8800GT; OCZ Vista 4GB dual-channel kit; Ultra X2 750W power supply; 2 x Seagate Barracuda 7200.11 500GB in RAID 0. Laptop: Acer Aspire 8730-6314;
Reply to Zoron
There are 701 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
