I have a newly purchased 7600 GT AGP card partially installed, but it needs a 4-pin power connector.
My question is which is the correct direction to install the 4-pin: should the red wire or the yellow wire be closer to the motherboard?
My manual is in Chinese, and the 4-pins fit either way, so I have no idea which direction is correct?
Also, there are several 4-pin cables from my PSU, as I am only running a single HDD atm. I assume any of those cables should work?
