Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Vista Ultimate 64 Bit Installation Problem
Forum Windows Vista : Vista General Discussion - Vista Ultimate 64 Bit Installation Problem
Whenever I boot up from the DVD I get the windows is loading files then after that it switches screens to the Microsoft Corporation screen and after about 10 seconds my computer reboots. My computer specifications are:
Intel Core2duo 6600
2GB RAM
P5W DH Deluxe
GeForce 7950 GX2
Sponsored Links
Is that an OEM or Retail. I just installed Visat 64 bit last night. Did you get to the serial number screen?
Reply to maximiza
Hard to say but trying another DVD drive is often the fix for these installation hang ups.
------------------------------ tehhardpro wrote :
notherdude u have an old hand. Having an old hand doesnt make sence. Cuz its old. get a new one.. seems like ur hand doesnt understand what it is writing. So placve it in ur rig instead of vista human orgnoids will amke more sense
Reply to notherdude
First thing I would do is check for a cooling issue, what is your CPU temp?
Second, are you using a USB thumbdrive for raid drivers? (check your boot sequence in the bios and make sure no USB drives are listed, I would only have CD then HDD listed)
What ram are you using?
Message edited by yamagiru on 05-09-2008 at 10:35:35 PM
------------------------------ ASUS P5E3 PREMIUM/WIFI-AP|Intel E8400|Patriot Viper 4GB PVS34G1333LLK|(x2) Seagate Barracuda ES.2 ST3250310NS 250GB|SILVERSTONE OP650|Scythe SCZP-1000|HT OMEGA CLARO Plus+|EVGA 512-P3-N841-A3 GeForce 8800GTS|Samsung 2693HM|Vista Ultima 64| Antec 900 case.
Reply to yamagiru
- 0 +
Do as the above guys said but we do need more information.
You should try placing the Installation Disk into a DVD Drive.
If that doesn't fix it then you need check for cooling issues.
Make sure you only have your Drive and HDD listed.
If you still can't then there could be a problem with your memory if you any extra try switching it out (make sure it's the same type).
Another unknown problem that creeps up is underperforming Power Supplies. Find out the Wattage and check to make sure all connections are firmly placed.
If you still have problems repartition and try again.
Reply to Cuddles
Try disabling firewire in the bios and make sure there are no USB devices listed in the boot sequence.
Message edited by yamagiru on 05-14-2008 at 12:00:49 AM
Reply to yamagiru
- 0 +
It is the OEM version and I have Windows XP 64 Bit on here right now. I have tried removing one of the memory sticks but it still stops at the same screen. My DVD drive and HDD are the only thing listed for boot but I have two hard drives. Also my power supply is 600w. CPU temp is 38C at idle.
Message edited by yshari on 05-14-2008 at 03:53:30 AM
Reply to yshari
i hope this does not happen to me i plan on doing all of this tonight and i am worried :(
Reply to artillery
when i intalled my Vista 64 i unplugged my XP boot drive and back up drive. I just replugged them in after installation. Dual boot works fine.
Reply to maximiza
There are 880 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
