Archived from groups: microsoft.public.pocketpc (More info?)
1: Can I set up an alternate font path so I can store fonts on e.g. a memory
card?
2: How can I DELETE .ttf fonts from \windows\fonts? I moved them all in, but
now I can't delete any, although they're not read-only
>card?
I don't think you can, but maybe someone has done this successfully.
Rename the font getting rid of the TTF extension then soft reset.
Delete the newly renamed files. .TTF files are always "in use" on the
PPC so you can't delete them normally.
__________________________________________________________________________________
Ed Hansberry (Please do *NOT* email me. Post here for the benefit of all)
What is on my Pocket PC? http://www.ehansberry.com/ Microsoft MVP - Mobile Devices www.pocketpc.com What is an MVP? - http://mvp.support.microsoft.com/
Hello happy customers, on Sat, 13 Aug 2005 11:55:56 -0500, "Ed
Hansberry, MS-MVP/Mobile Devices"
>>card?
>>>card?
>I reviewed Fonts On Storage some time ago :
>http://www.pocketpcfreeware.com/en/index.php?soft=726
>Works fine.
Cool. Thanks. I guess with an app just about anything is possible. :-)
Too bad it takes this much effort and can't be a simple reg hack. It
won't be an issue on WM5 though as fonts will just go in storage ROM
like everything else.
Thanks Tor. Works great. I put a link in \windows\startup so it loads
automatically
David Patterson
"torgamm" <reply.in.your.newsreader@discussions.microsoft.com> wrote in
message newsodsf1l6rimn75sh6a4dejbt71supgugcb@4ax.com...
memory
> >>card?
> http://www.pocketpcfreeware.com/en/index.php?soft=726 > Works fine.
> Didier B. / torgamm
Do you mean ROM or non-volatile RAM? Because the problem here is not with
the built-in fonts, but ones added by apps or by the user
David Patterson
"Ed Hansberry, MS-MVP/Mobile Devices"
<spamfree-silvernino@hotmail.spambegone.com> wrote in message
news:364tf15d69f1n418boiuki7a9n74k5jofs@4ax.com...
memory
> >>>card?
> >Works fine.
______
> What is on my Pocket PC? http://www.ehansberry.com/ > Microsoft MVP - Mobile Devices www.pocketpc.com > What is an MVP? - http://mvp.support.microsoft.com/
Well, same thing for our purposes. It is really flash-ROM, the
user-writable portion of the ROM.
>David Patterson
>memory
>> >>>card?
>> >Works fine.
>______
>> What is on my Pocket PC? http://www.ehansberry.com/ >> Microsoft MVP - Mobile Devices www.pocketpc.com >> What is an MVP? - http://mvp.support.microsoft.com/ >
