32bit program not running on 64bit??!?!???!!!!
hi guys
i recently downloaded a patch for this game (an unofficial one) and when i came to install it i get an error telling me that "this program is not compilable with your version of windows please contact the vendor for the correct version of the program (32bit or 64bit)" and i was like what the hell!!?!?!? I've never encountered this problem before and as far as i know 32 bit programs should work on 64 bit OSes just fine (i have windows 7 ultimate 64 bit btw)
i just want to know have you guys ever encountered such an error? how did you solve it/get past it?
any input will be most definitely welcomed and appreciated!
6 answers Last reply
More about 32bit program running 64bit
  1. I have never run into this. Did the error actually say 32 bit or 64 bit, or just this program is not compatable with your version? It makes a difference.
  2. hi and thanks for your input
    it says that the version of the program i have (the patch) isnt compatible with my version of windows and it asks me to check my system information to determine if i need a 32 or 64 bit version of the program. any ideas ??
  3. Off hand, no. Which game is the patch for and do you have the link it was downloaded from?
  4. PES 2011 ....im not sure if your familiar with the pesedit patches? its 3.7 version (the latest one i think) i tried downloading the 3.5 version assuming thre was an issue with the new release but it gave me the same error and i tried the windows compatibility options but to no avail. the link : http://www.pespatchs.com/2011/08/pesedit-2011-patch-3-7.html
    Well, is there a 64 bit version of the patch?
    Any chance this "unofficial patch" used a 16 bit installer? 32 bit programs will run on 64 bit, but 16 bit will not.
  6. I would recommend waiting until they put out a newer patch which works better for you.
Games Windows 7
