Hello I have Windows Vista 64-bit running in a stripped RAID and I recently discovered that my MBR is not located on the same HD that installed Vista, but is actually located on one of my non RAIDed drives.
Whenever I remove that drive the system wont boot up. Whenever I plug it back in, it works fine.
However, I want to remove this hard drive and I would like to know how to make my RAID drive that actually has VIsta installed on it the MBR drive.
I have tried doing a repair and loading the nvidia RAID drivers, but the system doesnt see my Vista installation, UNLESS I hook up the other hard drive OR I start the a full install (The RAID drive CAN be seen when Vista is asking where you want the OS to be installed)
In short, I want to transfer my MBR from my old hard drive to my RAID drive without having to reformat and stop from scratch.
Anybody have any ideas.
I hope this post makes sense.
Thanks.
Message edited by merrick97 on 05-29-2008 at 06:23:40 AM
Have you set in the BIOS to boot in the drive where you installed windows ?
If ont set it to boot in the drive where you installed windows then read this
Thats the mistake I apparently made in that I had my non RAIDed drive set as the bootup drive. I didnt notice this mistake until I removed the HD with the MBR and saw that I couldnt boot my system.
Im trying to fix that mistake without having to do a fresh install.
It seems like MS would have made this easy, but none of the current methods seem to work.
