hey guys i tried searching the forum for this but to no avail.
heres my problem, i recently upgraded vista 32-bit ultimate (from XP, fresh install). im experiencing sound output problems with my computer now as any mp3 played via VLC or WMP goes out on stereo sound. it sucks because i have a 5.1 setup. you guys know how to fix this up? everything works fine in games though. but the sound quality and the unusual stereo output is gut wrenching.
btw heres my spec:
q6600@3.0ghz
9600gt
3gb RAM single channel
ASUS p5k-se
i tried playing with the sound setup and everytime i press "test" all speakers works. grrrrrrrrrr!!!!!
I'm presuming you are referring to the audio settings on the control panel - where you can set quality and type, yah?? You've set them to full up, etc etc etc... correct??
If I'm not mistaken - and I may be since I didn't play with it much - Apps like VLC and WMP don't convert stereo sound to 5.1/7.1. Rather they decode and pass along whatever the source is. So if it's a stereo recording, you get stereo. Your game has multi-channel sound, and provides it's own output as well. So that's what comes out of the speakers.
On my own setup, I use the optical output from my soundcard into a (NAD T754) receiver, which has it's own D/A converter. I had played with the software that came with my card (Auzentech Prelude), but the hardware based decoding was clearly and immediately superior enough that, once I plugged in the digital output to the receiver, I never even thought about going back. After noting a recent driver update that added DTS support, I went and cleaned the audio apps that came with the card off of my comp entirely and just installed the new driver.
Message edited by Scotteq on 06-05-2008 at 03:45:29 PM
------------------------------Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground? Or the ones who illegally pay vendors to not support the first group?
Reply to Scotteq
im using the onboard audio of my mobo. is there anyway i can make wmp/vlc output on the 5 speakers that i have? xp can do that, i wonder why this silly vista cant! grrrrrrrrrr :|
Have you downloaded the latest drivers for your sound/motherboard?
Also, maybe get a decent sound card to replace the onboard sound, and then get the latest drivers from the manufacturer of the sound card. That'd probably solve the problems. I just picked up a Sound Blaster Audigy SE for $15 on clearance for my ASUS board. Sounds cleaner. Has 5.1, 7.1, and headphone modes. I like the included utility; it has a lot of tweaks and settings to play with. But, who knows, your onboard audio may be just as good as an Audigy SE card.
