Flash Player Problems?
I have been trying to run a cam program that works fine on my Windows XP computer with no problem but when I run it on my Vista I get a message that says "Macromedia Flash Player 8.0 r22 has stopped working" The details are.....
Problem signature:
Problem Event Name: APPCRASH
Application Name: live_house_broadcaster.exe
Application Version: 8.0.22.0
Application Timestamp: 4310d1ee
Fault Module Name: IPCamera_MJPEG.ax
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 2a425e19
Exception Code: c0000005
Exception Offset: 000aa58e
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional Information 1: 1497
Additional Information 2: 34cfe57b151ab9a0989be7a6b64ca0e8
Additional Information 3: 5c09
Additional Information 4: dd9a6a12bc846fb6613fee1980cd3758
I have tried may times of unistalling and reinstall Flash and I do have the lasted flash player installed. Any ideas as to what I can do? This is driving me crazy !
6 answers Last reply
More about flash player problems
  1. Uninstall flash player with this tool, then reinstall it from the Adobe web site.
    http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_14157
  2. I already done that many times. :(
  3. Well, check with the manufacturer of your cam program to see if it is VISTA compatible. You didn't mention if you are using VISTA 64 or 32.
  4. I have been in contact with them and they don't seem to know what the problem is. There are many people who use it with Vista. How do I check to see if I am using 64 or 32 ?
  5. Right click on My Computer, click on properties, version listed under system. If you didn't build your PC yourself, it's 32.
  6. There is some oem systems shipping that are 64 bit now.
Flash Player Windows Vista Windows XP
