Tom's Hardware > Forum > Home Theatre > HDTV > unusual tv problem
unusual tv problem
Forum Home Theatre : HDTV - unusual tv problem
Archived from groups: alt.tv.tech.hdtv (More info?)
I have Samsung hdtv ready direct view 27" TV, and couple of months ago,
picture went bad (posterized, on a grayscale, some lighter shades very
dark, some darker light), but only when I used 480p output from Sony
DVD player. IT WORKED NORMAL BEFORE!!! I checked picture with the other
DVD players, but it was always bad with 480p and normal with 480i
output. With a waranty expired and no chance to fix it, I just
continued to use 480i only. But couple days before, I connected XBOX to
my TV with HD cables and set it up for all (480p, 720p and 1080i),
played "Enter the Matrix" (1080i), "Top Spin"(480p), etc. and it worked
fine. A little darker picture, but no posterization, good colors...I
tried my DVD player again, bad... So, is there any reason that my TV
like XBOX and not DVD player. BTW, I tried with couple cables, couple
DVD players, set it up correctly, and like I said, it WORKED for before
with my Sony. Is there any difference between 480p game signal and 480p
DVD signal?
Sponsored Links
Probable artifacting due to compression or processor techniques within the
DVD. <
>Playing the same DVD Movie with two different pieces of equipment. One
>produces the problem, the other does not. This indicates the tele is
>probably working ok. <
> Have you tried the SONY DVD on another tele , connected the same way, to
> see if the symptom is evident there??
"celo" <sbegovic1@comcast.net> wrote in message
news:1104227809.823200.222730@f14g2000cwb.googlegroups.com...
> DVD signal?
Reply to Anonymous
to
No, I tried other two DVD players, but I'll try that too, just to be
sure.
Thank you
Reply to Celo
There are 587 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
