So I want to get a new case. I need something that will fit into this space.
I need to keep it under W: 9.5" H: 19" and I have plenty of depth.
So I need something that has a solid construction and supports 120mm fans. I want to keep it around $100 and definitely dont want to spend over $150. I need it to also support an 8800GTX and a X-Fi Platinum front panel.
Really not into bright lights and tacky looking cases. I can also live without a window.
I own the black version of this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119029
So far I really like the construction and it looks awesome but doesnt have a side vent and doesnt support 120mm fans.
Any ideas would be awesome.
