OK, so I have Windows Vista Home Premium 32-bit upgraded motherboards from an Nvidia nForce 650i SLI (ASUS P5N-E SLI) to an ASUS P5N-D SLI. I also added a new video card and new RAM to this new motherboard. Needless to say, the ethernet card would not let me on my home network with this new motherboard. Everything else was fine up until I went ahead and switched BACK to my old motherboard. Everything went back the way it was, except for the new RAM and new video card, which I stuck on my old MB Now, when Vista loads, the green loading bar freezes and I get the BSOD. My usual message is
IRQL_NOT_LESS_OR_EQUAL
Technical Information:
*** STOP: 0x00000000A
Now, the thing is, when I pop in my Vista recovery disk from Velocity Micro and I boot from the CD drive, I get the same issue (or one that says: "SPT_FILE_CORRUPT). One time, it may have even gotten to the screen to format and reinstall Vista, and then the BSOD came up.
Is this a hardware issue? I don't understand it. Please help :-\
But if that doesn't work, you're looking at a clean install anyhow.
------------------------------Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground? Or the ones who illegally pay vendors to not support the first group?
Reply to Scotteq
Did you confirm the new RAM is set to mfg. specs? Particularly the voltage?
Give us all the details on this new RAM
------------------------------tehhardpro wrote :
notherdude u have an old hand. Having an old hand doesnt make sence. Cuz its old. get a new one.. seems like ur hand doesnt understand what it is writing. So placve it in ur rig instead of vista human orgnoids will amke more sense
Reply to notherdude
