I know it sounds silly but here is my question and where I am going. I currently have an ATI X850XT PE and am planning on upgrading to the 2900.
My issue is that my PC runs 24/7, but the display is only on a few hours a week - the rest of the time the screen is blank and the machine is basically a file server.
I just upgraded my CPU from an old (Pre speed step) Pentium D950 to an E6600 - at least partially so that my machine wouldn't draw as much power when it was not doing much, and also so I didn't have to put an air conditioner in the computer room.
I have no problem with the ATI card drawing a couple hundred watts while I am gaming, but I wish there was a way to drasticall underclock it, or even disable it completely when I am not using it. 99% of the time a standard VGA card would suffice.
Is there anyway to dynamically underclock the card, or turn it off when I am not using it? Power management on my PC will turn off my LCD monitor which draws almost no power, but leaves the 100 watt video card running.
When I am not gaming, the only thing the video card needs to do is basic VGA functionality like windows desktop and maybe internet explorer.
Suggestions?
Suggestions?
