I'm building a new system that I plan on using primarily for photography (ie photoshop, film scanning) and possibly a little gaming. Would like to keep it reasonably quiet. Looking to spend about about $2k. Any advice/feedback? thanks!
Processor:
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775
Cooler:
Scythe SCNJ-1100P 120mm Sleeve CPU Cooler
Mobo:
MSI P965 Platinum LGA 775 Intel P965 Express ATX Intel Motherboard
RAM:
4GB Patriot eXtreme Performance 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Harddrive:
2 x Seagate Barracuda 7200.10 ST3500630AS 500GB 7200 RPM SATA 3.0Gb/s (RAID 0)
Vid Card:
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB GDDR3 PCI Express x16 HDCP
Power:
AeroCool ZERODBA ZERODBA-S620 EPS 12V & ATX 12V 2.02 compliant with Powerful Dual +12V Rails 620W
Case:
Antec Performance One P180 Silver cold rolled steel ATX Mid Tower
Optical Drive:
Sony NEC Optiarc 18X DVD±R DVD Burner, OEM Version Black SATA Model AWG170S-B2
Monitor:
SAMSUNG 226BW Black 22" 2 ms (GTG) DVI Widescreen LCD
Processor:
Cooler:
Mobo:
RAM:
Harddrive:
Vid Card:
Power:
Case:
Optical Drive:
Monitor:
