Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Vista 32bit Defrag Problem
Forum Windows Vista : Vista General Discussion - Vista 32bit Defrag Problem
ok so i ran disk defrag on my 160gb/5400 hdd which had about 26gb left, after the defrag instead of freeing up space i now only have 7gb.
i have never had this problem before, on any OS and cant really find much on this.
thanks guys i know you will come through!
Sponsored Links
What defrag program was it? Vista has one that runs automatically in the background.
------------------------------ tehhardpro wrote :
notherdude u have an old hand. Having an old hand doesnt make sence. Cuz its old. get a new one.. seems like ur hand doesnt understand what it is writing. So placve it in ur rig instead of vista human orgnoids will amke more sense
Reply to notherdude
thats the one i used, the one thats built into the windows OS
it said it was finished, just like normal..
Reply to typerazor
Maybe your free space was being reported incorrectly before the defrag and the defrag fixed it. That's my guess but it's just a guess. I have seen defrag adjust free space before. Yours was a big adjustment, LOL
Message edited by notherdude on 08-18-2008 at 02:32:41 AM
Reply to notherdude
i thought something like that might have happened, i checked in ubuntu and everest, both report the same.
and what is the strangest thing, is the longer i am on the computer (ex. using firefox, etc) the space gets smaller and smaller.
is this unique to vista? im thinking it didnt finish defrag and still is running in the background?
i just checked all my files in C drive at it should add up to 98, not 134
thats a rather large difference...is it all being held in temp?
ok i ran it again..now i have 17.5gb free
what is going on
Message edited by typerazor on 08-18-2008 at 01:26:08 PM
Reply to typerazor
Ah, maybe defrag had appropriated some space as a scratch drive and then when it was finished it gave it back.
Reply to notherdude
Hi,
Defrag will never create new space; it can only consolidate existing free space into larger contiguous areas.
It could be VSS activity in Vista32 during defrag that results in space consumption.
Please see the following links
http://support.microsoft.com/kb/312067
Althought the following deals with Diskeeper 2008 specifically, it describes the issues between VSS and defrag
http://www.diskeeperblog.com/archi [...] re_sp.html
Best Regards
Representative
Diskeeper Corporation
Reply to DiskeeperRep
just ran disk check, for errors and boom i for some reason a corrupt cluster
30gb free now and burn in hell vss
thanks diskeeper that would have been my other option
Reply to typerazor
There are 1231 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
