serious problem need help urgent
I get all blacked out icons on my pc after it runs for around 4 hours. what is the possible reason? i have attached the screen shots
http://img178.imageshack.us/my.php?image=32877243fu9.png" class="img lazy">
1 answer Last reply
More about serious problem urgent
  1. Your most likely cause is overheating. You should check out a few of the tempertures, your CPU tem, GPU temp, as well as the MB temp. Motherboard Monitor will tell you if you don't have a program already.
Icons Windows XP
