Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Vista keyboard problems -- shortcut key issues
Forum Windows Vista : Vista General Discussion - Vista keyboard problems -- shortcut key issues
My wife is having some issues with her laptop (Gateway). She is running Vista 32 bit, and up until this points she has not had a problem with anything.
Now out of nowhere, she is having some funny problems with the keyboard. When she types (email for example) sometimes the different letters that are pressed act like a shortcut key. It will open anything from "My comp" to the start menu, and everything in between depending on the key pressed. I thought maybe she was doing something to it, so i took it for awhile. It will pop up the start menu even when its just sitting on a table! It will pop up, then down, repeat....
I am thinking a can of air and some time blowing things around might fix it, but i wanted to get some input on what else could be the culprit. Any ideas?
Sponsored Links
Try a different keyboard. If that doesn't work, you could possibly have a program conflict causing it, just speculation on my part. Also, try a USB keyboard if you have one.
Reply to badge
- 0 +
Sounds like the Windows key is sticking... try carefully popping it off and reseating it. Make sure it's clean underneath as well.
------------------------------ Desktop: Windows 7 Professional 64-bit; Intel Q6600 CPU; E-VGA 780i SLI motherboard; E-VGA E-GeForce 8800GT; OCZ Vista 4GB dual-channel kit; Ultra X2 750W power supply; 2 x Seagate Barracuda 7200.11 500GB in RAID 0. Laptop: Acer Aspire 8730-6314;
Reply to Zoron
- 0 +
Bingo! Stuck key. Windows, or Shift, or Control all make the computer do strange things when they're stuck, since 'Control N' does not equal the first letter in Nancy... :pt1cable:
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
There are 960 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
