I purchased a used PC with a 15" flat panel monitor, but the manufacturer does not provide any online support.
XP is just using a standard plug and play driver, but I've noticed that when I have used system information reports, specifically, Everest, it does not have the monitor type.
How do I configure XP to recognize that this is a LCD monitor??? Here's the spec's that I've googled the model number:
Impression 5LS
General MPN: 9002380
Display Type: Flat panel display / TFT active matrix
Width: 15.4 in
Depth: 8.1 in
Height: 15.6 in
Weight: 9.9 lbs
Display
Diagonal Size: 15"
Viewable Size: 15"
Dot Pitch / Pixel Pitch: 0.3 mm
Max Resolution: 1024 x 768 / 75 Hz
Max Sync Rate (V x H): 75 Hz x 62 kHz
Video Bandwidth: 80 MHz
Controls / Adjustments: Brightness, contrast, sharpness, color balance, clock
Display Screen Coating: Anti-glare, hard coating
Image Brightness: 250 cd/m2
Image Contrast Ratio: 350:1
Video input
Analog Video Signal: RGB
Expansion / connectivity
Interfaces: 1 x RGB input - 15 pin HD D-Sub (HD-15)
Power
Voltage Required: AC 100/240 V ( 50/60 Hz )
Miscellaneous
Compliant Standards: FCC Class B certified, CE, MPR II, CSA, UL, cUL, DDC-1,
DDC-2B, DHHS, DOC-B, EPA Energy Star, ISO 9241, NOM, TCO '99, VESA DDC/CI
