Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > New build. Which Motherboard to choose? Please help
Forum Motherboards & Memory : General Motherboard - New build. Which Motherboard to choose? Please help
Guys I've decided to invest in a new system and this is what I've decided to spend on :
Processor: Intel E6300 (overclocked to 2.8-3.2)
RAM: Geil PC6400 2GB CL4
Cooler: Artic Freezer 7
Case: Antec 900
PSU: Hiper 530 W Type M
Hard Drive: 250GB Western Digital 16MB cache
Graphics: nVidia 320MB 8800GTS
The problem is that I can't decide which motherboard to choose from the following list:
Gigabyte GA_P35C_DS3R DDR2 + DDR3 support.
(Link: http://www.overclockers.co.uk/show [...] ubcat=913)
Gigabyte GA_P35_DS3P DDR2 only
(lINK: http://www.overclockers.co.uk/show [...] ubcat=913)
Gigabyte GA_P35_DS4 DDR2 only
GIGABYTE GA-N650SLI-DS4 DDR2 Sli
(Link: http://www.dabs.com/productview.as [...] 000,50509)
In some 6-8 months time I intend to upgrade to the quad core (penyrn based?) processors and hopefully overclock them. I'm not sure which motherboard out of the above list is going to be a good investment therefore I need some advice into which motherboard should I choose.
Any help will be greately appreciated. Thanks in advance.
Sponsored Links
I am going to go with a very similar build, and am trying to figure out which P35 board to buy as well, so I'll be following this thread.
I noticed that the Gigabyte GA_P35C_DS3R DDR2 + DDR3 support only has 2 DDR3 DIMM slots, so you might want to keep that in mind.
Are you considering the Asus P5K board?
Reply to Hathorian
Yes since you have mentioned I have also just looked into the Asus P5K board but I'm still totally confused into which board to select :?
I hope some one is able to tell me which board to select since I don't have a clue
Reply to tornado16
Quote :
Mate, I think no one at this time has a clue. Didn't hear about any comparative revews between boards based on P35.
I am myself in a dillema since have to decide by tomorrow due to my current work conditions - I won't be able to purchase later and find time to build (so must decide on Gigabyte - the only P35 available [anywhere?] now).
Well, I don;t know if it'll help, but maybe you saw these reviews?:
Gigabyte GA-P35-DS4
Gigabyte-P35-DS3R
same GA-P35-DS3R
Gigabyte GA-P35-DQ6
Btw, careful, none seem to suport crossfire (well, I would doubt it with 1x16 and another 1x4 PCIe).
Reply to freelance
After doing some extensive research I've went ahead and placed the order on Gigabyte GA_P35C_DS3R DDR2 + DDR3 Motherboard. Now I'm just waiting fot it to be delivered to me hopefully in the next 5-6 days. I'll let you guys know what the mobo is like when I get it and also hopefully post the pictures up of my new rig once I've finished building it.
Freelance let me know which motherboard you buy because I might be building another computer after this one so it will be worthwhile if you could share your experiance.
Btw I have one question, does anyone know if it is worthwhile to upgrade to 4GB of DDR2 ram or is 2GB going to be enough? I will be mostly be using my computer for Gaming, watching Movies, Downloading stuff and some photoshop work.
Thanks guys.
Tornado
Reply to tornado16
tornado16 I think I'll take a P35-DS4 tomorrow +E4300 - I'll stick to a more "budget" solution for now. My goal is to go for a relatively moderate OC @2,6 or max 2,8Ghz, which should be more than enough for me/us, since the rig is for the whole family use (Net, Office, games for my son, and ... for ME :D ).
2Gb of DDR2 seem fine to me; only Photoshop bothers me a bit... can't say anything definite. btw it seems Vista only recognises max 3gb really, don't have one for the moment, so just speculating.
Reply to freelance
Just went through a thread here at TGForumz where people clarify in more detail about 32bitOS recognising approx 3,12Gb and 64bitOS recognising more than 4Gb - have a look at this thread though: System with more than 4 GB RAM
"Joke" on that thread gives a reference to the MS explanation of that:
MS explanation on 4Gb of RAM
Reply to freelance
I went for the GA-P35-DS4 and E4300, OCZ 1066mhz 2G kit, NoctuaNH-U12F, Antec P180 (PSU Corsair 620W). Other stuff later. Unfortunately, I am moving (another apartment is not far, but the hussle...) and I don't have any idea when I'll actually build and test the rigggg :( :evil:
Reply to freelance
Anandtech has been running a series on p35's Latest one is:
http://www.anandtech.com/cpuchipse [...] spx?i=2995
Might be worth following. And then there's the x38 MB's arriving soon.... Decisions, decisions.
Reply to croc
Quote :
Hm, quoting myself. This is something new!
Well, just wanted to warn you guys aout the so-called compatibility between NoctuaNH-U12F and GA-P35-DS4. Despite the high NB passive cooling (horizontal fins), Noctua claims these two should fit fine and they somehow do, or sort of... Basically, when I tried to install the Noctua it just could not stick to the CPU, because one side was already sitting on the very high NB cooler, just a little bit, but there nonetheless.
So, when I tried to tighten the Noctua in place, I had encountered (of course) some resistance from the NB fins and could not feel when I should stop tightening the cooler. That is not right! Now the first few fins on the NB are sticking to eachother and I have no idea if I over-tightened the cooler to CPU or not :evil:
Didn't finish with the rest yet.
Reply to freelance
tornado16 - just to give you some sort of a feedback about the results of my build on the P35-DS4 - here is a quickly done overview with the E4300@2,8Ghz(9multi - as I said, that's was maximum target OC I wanted) + NoctuaNH-U12F (one fan only, on the RAM side - impossible to set up push-pull when cooler facing rear) + OCZ 2Gb Kit DDR2-1066Mhz(5-5-5-14/2t - native is 5-5-5-15/2t, not a big change :? ) + case actually happened to be P182 (not P180 as reported before - the box was P180, but I found inside the P182; heard people had same experiences...) + PSU Corsair 620W. Well, with VGA... I had to cut again since had an irrezistible offer to get a 8600GT for a quarter less price - so, 8600GT (since its a family rig, wtf, its enough).
Upgraded at once to BIOS F4. PCI @ Auto (tried and can work with higher speed, above 100). BIOS @ Auto suggests cpu voltage 1,3250v. I saw on legionhardware that their P35-DS4 BIOS was suggesting 1,25v voltage as Auto - that is a discrepancy between Gigabyte test board and the one that I bouhgt/was on regular sale. Anyway, I gave 1,25v a try and it decreased the temps well enough without affecting stability.
So, my temps in this P182, 3fans @ low + one more fan added in front @1000r, under TAT @ 100% (1,25v Vcore, VDIMM auto [which is 1,8v, while OCZ specs are actually 2,3v]), ran stable 50min, are:
- TAT - 61C/61C;
- Core Temp 0.95 - 62C/62C
- SpeedFan 4.32 (Core0/Core1) - 47C/47C.
Btw latest CPU-Z shows that Vcore is 1,216v, latest speedfan 1,22v, latest CoreTemp 1,3250v.
With Orthos blend stress CPU and Ram for 1hrs10min:
- TAT - 54C/54C;
- Core Temp 0.95 - 56C/56C
- SpeedFan 4.32 (Core0/Core1) - 42C/41C.
CPU-Z shows that Vcore is 1,2v, speedfan the same, while CoreTemp 1,3250v.
All was fine, played a bit and it was ok. One concern - I am curious if the Vcore (set by me to 1,25v in BIOS at the time of the test) reported by CPU-Z and SpeedFan in both cases are vdroop or software misreading? From variations under Orthos and TAT it might seem it is a real vdroop of 0,016 up to 0,05?
Now I lowered the FSB and the Vcore even more and have:
- CPU E4300@2,6Ghz(9x),
- Vcore 1,2475V (I think; well the next one under 1,25v),
- VDIMM on Auto-1,8v (5-5-5-14/2t),
- PCI @ Auto
And again all is fine. FPS in smaller res smooth, no problems whatsoever.
Very good board for me and my purpose IMO.
Cheers ppl.
Reply to freelance
There are 1331 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
