Hello everyone, I have a newly built computer and I'm having problems installing vista onto it. It keeps giving me this error once i get through all the setup.
I'll start off clicking on my HDD in order to install vista onto it..
I can get it to go to this screen here, but it will never leave 0%..
After about 5-10 minutes of staying at 0% it will bring up this error screen..
After hitting okay it will bring me back to the beginning of the install process. If i continue through again my HDD will not be on the list anymore. I'll have to restart my computer before it will recognize the HDD again. I've tried multiple times with the same results, any help would be lovely. Thank you.
I've had problems with Vista setup formating a 'brand new' hard drive. A hard drive that has never been formatted prior. You can pop in a Windows XP installation CD and format the new HD that way, then Vista will properly recognize it is indeed a hard drive (one of those things?! LOL). Or try hooking up to an XP system and fromatting it from disk management.
I second this idea. Try deleting any existing partitons with XP or some othe utility (such as fdisk), then partition it, format ntfs, and then put it back in for vusta to chew on. I can't rmember but did you say this drive was working on any other system before. If it's brand new it could be bad. Try the HD mfgs. utilities disk on it you can DL from mfgs site if you suspect this could be possible.
------------------------------tehhardpro wrote :
notherdude u have an old hand. Having an old hand doesnt make sence. Cuz its old. get a new one.. seems like ur hand doesnt understand what it is writing. So placve it in ur rig instead of vista human orgnoids will amke more sense
Reply to notherdude
If the Seagate HDD is retail it came with a drive preparation disk, if its OEM download the disk from Seagate it may save you some time.
Note; Installing from scratch make sure you're not overclocking anything, install with default settings first then OC later if thats your intentions.
Also you may want to double check your OCZ memory settings in the BIOS setup against the OCZ websites spec settings for the memory including the voltage setting, you may have to set those manually if your M/B doesn't default them to their proper settings.
Also make sure the SATA headers are set to IDE in the BIOS setup, since you're installing from a SATA optical drive.
Message edited by 4ryan6 on 09-20-2008 at 07:05:22 PM
------------------------------Badges? We don't need no stinkin' badges!
Reply to 4ryan6
