Code:
[root@Alicia echo]# yum install kmod-wl
Loaded plugins: langpacks, presto, refresh-packagekit
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package kmod-wl.i686 0:5.60.48.36-2.fc15.6 will be installed
--> Processing Dependency: kmod-wl-2.6.40-4.fc15.i686 >= 5.60.48.36-2.fc15.6 for package: kmod-wl-5.60.48.36-2.fc15.6.i686
---> Package kmod-wl-2.6.40-4.fc15.i686.i686 0:5.60.48.36-2.fc15.6 will be installed
--> Processing Dependency: kernel-uname-r = 2.6.40-4.fc15.i686 for package: kmod-wl-2.6.40-4.fc15.i686-5.60.48.36-2.fc15.6.i686
--> Processing Dependency: wl-kmod-common >= 5.60.48.36 for package: kmod-wl-2.6.40-4.fc15.i686-5.60.48.36-2.fc15.6.i686
---> Package broadcom-wl.noarch 0:5.60.48.36-1.fc13 will be installed
--> Finished Dependency Resolution
Error: Package: kmod-wl-2.6.40-4.fc15.i686-5.60.48.36-2.fc15.6.i686 (rpmfusion-nonfree-updates)
Requires: kernel-uname-r = 2.6.40-4.fc15.i686
Installed: kernel-2.6.38.6-26.rc1.fc15.i686 (@koji-override-1/$releasever)
kernel-uname-r = 2.6.38.6-26.rc1.fc15.i686
Installed: kernel-2.6.40.3-0.fc15.i686 (@updates)
kernel-uname-r = 2.6.40.3-0.fc15.i686
Available: kernel-PAE-2.6.38.6-26.rc1.fc15.i686 (fedora)
kernel-uname-r = 2.6.38.6-26.rc1.fc15.i686.PAE
Available: kernel-PAE-2.6.40.3-0.fc15.i686 (updates)
kernel-uname-r = 2.6.40.3-0.fc15.i686.PAE
Available: kernel-PAEdebug-2.6.38.6-26.rc1.fc15.i686 (fedora)
kernel-uname-r = 2.6.38.6-26.rc1.fc15.i686.PAEdebug
Available: kernel-PAEdebug-2.6.40.3-0.fc15.i686 (updates)
kernel-uname-r = 2.6.40.3-0.fc15.i686.PAEdebug
Available: kernel-debug-2.6.38.6-26.rc1.fc15.i686 (fedora)
kernel-uname-r = 2.6.38.6-26.rc1.fc15.i686.debug
Available: kernel-debug-2.6.40.3-0.fc15.i686 (updates)
kernel-uname-r = 2.6.40.3-0.fc15.i686.debug
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
[root@Alicia henry]# rpm -qa | grep -e kernel -e broadcom-wl -e kmod-wl | sort
abrt-addon-kerneloops-2.0.3-1.fc15.i686
kernel-devel-2.6.40.3-0.fc15.i686
kernel-headers-2.6.40.3-0.fc15.i686
[root@Alicia henry]# yum update kernel
Setting up Update Process
No Packages marked for Update
[root@Alicia henry]# yum install kmod-wl
Attempting to install Broadcom wirless
Already run "yum update"
"gcc" and "kernel-devel" are installed
rpm fusion repos have been added
Any ideas?
