you should have gotten a OEM disk with a new build but you usually have to tell them right up. I know with my build I always got an oem starting with, windows 1 the, then 3.1, 95, 98, xp. Go back to the store with proof of what you got and get it.
ummm..you mean slipstream xp with SP3? It only takes one CD. Here are the instructions, I would like to know if you can do it with your XP upgrade CD. I'm busy working . I can try it later if I have time.
Not sure, I have used XP pro, Vista 64 and Vista 32. Be interesting to see if you can get a SP3 slipstreamed CD out of the XP update disk. I would try whatever option was opn, XP Pro and see what happens. Probably nothing 8).
Yeah, use the XP upgrade disk just as you would an XP disk and try an slipstream SP3 on a CD and load it on your system. I will try it myself when I get time.
