PC PARTS LIST?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : PC PARTS LIST?
Profile: newbie
More Information
I am looking at building a new pc my first attempt.
i want to use the computer for my educational use, like word typing, creating web pages, storing wedding pictures (really loads of them), want to store them on dvd, i lalso use programming languages like, visual basic, python etc to make programmes.
and after much trawling through the internet I have come up with the following spec:
AMD Athlon 64 X2 3800+ 2.0GHz
Gigabyte GA M59SLI-S4 AM2
400 GB SERIAL ATA II HARD DRIVE
2GB RAM (1GBx2)
LiteOn DH-18A1P-18C 18X DVDRW
Microsoft Windows XP
i am not into gaming! will the onboard graphics cards do?
which garphics card would you recommend?
how much can i sell it for? any ideas?
I would apreciate any comments or advice on this spec.
thanks Windog
Related Pr oduct
Profile: journeyman
More Information
Quote :
2GB RAM (1GBx2)
thanks Windog
http://forumz.tomshardware.com/har [...] internal=1
:roll:
Profile: journeyman
More Information
oops double post :oops:
Profile: journeyman
More Information
Hi windog,
I wouldn't go with anything from AMD until they introduce some worthy cpus. Also, with the current price of XP and its limited life expectancy (01/28/2008) and especially with the fact that you are not planning to stress your things too much, I would surely consider the cheaper Vista Premium OEM package (and you can learn about the future too :) ). Since you do not need HIGH fps, I would also suggest a 1600 series ATI graphics card; they are cheap, very well supported and will give you all the performance you need.
Those are just my thoughts, I am sure others may have better ideas (and possibly not so rude as you have seen so far).
--DD
Profile: enthusiast
More Information
Rough Suggestion:-
Cheap dual core CPU (X2 3600/E4300? - Avoid Pentium Ds)
Decent motherboard (P965 chipset for Intel, Nforce chipset for AMD - I like ASUS and Gigabyte boards)
2GB DDR2 Ram (667/800mhz, Corsair value ram is good stuff)
Cheap video card (7300GT or thereabouts)
HDD (Seagate or Western Digital SATA, how big does it need to be?)
DVD/RW drive
Case ( :roll: Anything will do)
PSU (Something around 400 -> 500W from a decent brand like Antec, Thermaltake etc)
XP Home or Vista Home Premium
Something like that would give you a decent PC with a good upgrade path for the future.
Profile: journeyman
More Information
Mandrake's list does look nice. From his selectables, I think I would go with any Intel duo cpu; Seagate (7200.10 cause of the price/performance ratio); the bigger PSU, 500W min (bigger is better :oops: ); and Vista Premium OEM for ~$112,
One place to save a little money with your stated requirements; you should get the cheapest memory you can (with the lowest latency). A lot of issues are involved but 533Mhz 4,4,4,12 memory will give you very near the same performance as 800 5,5,5,15 on a 1066 fsb. I have 4G of 5,5,5,15 on an x6800 and memtest86+ says I get about 3.6G throughput. When I slow the memory down to 533 4,4,4,12 I still get around 3.6G. I do overclock my memory and I get around 4.1G but it cost a lot extra to be able to do 900 4,4,4,12. :) See, it can get complicated so just go for any 2G ddr2 kit using 4,4,4,12 corsair memory and you'll do just fine.
Best
--DD
Add a reply
Google Ads
