Sign-in / Sign-up
Ubuntu 11.04 wired connection doesn't work
  • Windows 7
  • Connection
  • Ubuntu
Last response: in Open Source Software
September 7, 2011 9:28:23 PM
Hi. I installed Ubuntu 11.04 on my laptop yesterday and using windows 7 at the same time. The multi booting you know.
But the wired network doesn't work at all when I boot with Ubuntu. Actually it didn't recognize the network connection
at the first place I was installing.
With windows, it works perfect. I surfed around in google for several hours, but couldn't find an answer.
Any suggestions?
More about : ubuntu wired connection work
September 7, 2011 10:39:50 PM
Either provide the laptop model or the output of lspci as this is likely a driver issue
m
l
September 8, 2011 1:25:28 AM
This is what I see when I type lspci
The laptop model is samsung R590
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 12)
00:01.0 PCI bridge: Intel Corporation Core Processor PCI Express x16 Root Port (rev 12)
00:1a.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 06)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 06)
00:1d.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 06)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 06)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 06)
02:00.0 VGA compatible controller: nVidia Corporation GT216 [GeForce GT 330M] (rev a2)
02:00.1 Audio device: nVidia Corporation High Definition Audio Controller (rev a1)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8192E Wireless LAN Controller (rev 01)
07:00.0 Ethernet controller: Marvell Technology Group Ltd. Yukon Optima 88E8059 [PCIe Gigabit Ethernet Controller with AVB] (rev 11)
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
3f:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 02)
3f:02.2 Host bridge: Intel Corporation Core Processor Reserved (rev 02)
3f:02.3 Host bridge: Intel Corporation Core Processor Reserved (rev 02)
m
l
September 8, 2011 5:31:01 AM
This is the line we care about. Since you're running a fairly recent Ubuntu, you should have an appropriately new kernel with support for this card built into the sky2 module that supports Marvell Yukon cards (to verify, ensure that sky2 is loaded into the kernel, a quick check is lsmod|grep -i sky). If it's not loaded, try loading it with sudo modprobe sky2.
Once loaded, list the output of sudo ifconfig -a to see if the interface is known by the networking subsystem.
m
l
