Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > connect 2 wireless routers via wireless lan
Forum Wireless Networking : Wireless General Discussions - connect 2 wireless routers via wireless lan
what im trying to do is connect 2 wireless routers together without cables between them.
i have a Netcomm NB5+4W (ADSL 2+ modem,wireless,4 port switch) which is located in the living room,
the other is a D-Link DI-524 (wireless router, 4 port switch) which will be located in the garage in my backyard.
connected to router 1 (netcomm) is: phone line (internet), 4 PCs (wired ethernet), 2 laptops (wireless ethernet).
connected to router 2 (d-link) is: 1 PC (wired), 1 XBOX (wired).
the part i need help with is the wireless link between the 2 routers so that all PCs, laptops and the xbox can connect to each other to share files, etc
---interet--->router 1--(wireless)-->router 2
4 PCs 2 laptops 1 PC XBOX
| HOUSE | | GARAGE |
Sponsored Links
Router 2 has to be put into Bridge mode (if it supports it) or you need a wireles bridge.
Grumpy
Reply to Grumpy9117
- 0 +
router 2, the d-link di-524, with the firmware it came with when i bought it doesnt support bridge mode.
i checked on the d-link website and downloaded the latest firmware for it, the updated firmware now allows the d-link to act as a wireless bridge.
Reply to davo88
There are 814 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
