How do I connect my subwoofer to the receiver???
Archived from groups: alt.tv.tech.hdtv (More info?)
This should be a pretty easy problem to solve compared to most issues
that posters are dealing with:
I'm in the middle of connecting my mostly new home theater system and
cannot figure out how to connect the sub to the receiver.
The Yamaha receiver (HTR-5760) has two jacks labelled "subwoofer".
One is the the section labelled "Multi-Channel Input" and the other in
section "Pre Out".
The sub (Klipsch KSW12) has all kinds of connections that don't seem
to match up with the receiver jacks - unless I REALLY don't understand
what is going on here. The sub has 2 pair of red/black screw-down
connections labelled "Speaker In". There is another connection (2
jacks) in the "Line In" section labelled "R" and "L/LFE".
What do I need to do??
Reading the manuals for both components wasn't much help.
Hopefully someone out there can help me or I will have to wait until
Monday to call the store, Yamaha, or Klipsch. And, of course, I am
very anxious to turn this system on!
Thanks for any help,
Bob Henninger
4 answers Last reply
More about connect subwoofer receiver
  1. Archived from groups: alt.tv.tech.hdtv (More info?)
    <katz1@ptd.net> wrote in message
    news:rgjet0p4lsvdjbbnr2kbnab7r2sk6b1p14@4ax.com...
    > section "Pre Out".
    > Bob Henninger
    Connect the one in the PRE OUT section to the LFE input on the sub.
    Leonard
  2. Archived from groups: alt.tv.tech.hdtv (More info?)
    X-No-archive: yes
    > section "Pre Out".
    Pre-Out (subwoofer) is preferred method.
    Use the L/LFE input on the sub.
    > Bob Henninger
  3. Archived from groups: alt.tv.tech.hdtv (More info?)
    and then make sure u turn the volume up. oh and one more thing. on your
    yamaha reciever u have to tell it "Subwoofer... YES". it comes out of the
    box as the sub is turned off. be carefull. it might be that easy.
    if u just got that sub, id consider returning it and getting the Klipsch
    RW-12. the KSW is the lower end "synergy" series Klipsch offers. The
    Reference line RW-12 u can probably get for a comporable price and it is a
    much nicer piece.
    joe
    "Leonard Caillouet" <no@no.com> wrote in message
    news:mRIBd.21683$jn.4883@lakeread06...
    > > section "Pre Out".
    > > Bob Henninger
    > Leonard
  4. Archived from groups: alt.tv.tech.hdtv (More info?)
    Thanks guys,
    I bought a new cable and a "Y" to connect to the R and LFE and it
    sounds great.
    Appreciate the help.
    Bob
    >section "Pre Out".
    >Bob Henninger
HDTV Connection Home Theatre Product
