Bewildering Network Problem
Forum General Networking : Network General Discussions - Bewildering Network Problem
I just installed an EVGA 680i A1 LT motherboard with no problems (it has an on-board network adapter). The system booted up all the way, I installed the board drivers and everything worked great except the internet.
The internet works fine on the other computers on the network, whether connected to the router or directly to the modem. I tried resetting both router and modem but that didn't work. I tried static and dynamic IP. I even reinstalled WinXP32, because the manual said the OS needed reinstalling. Now, with a non-updatable OS, my hands are tied.
What's going on? Did I get a defective board?
Also, at the start it was working but very slowly. It would load half the "Google" image in 2mins, then stop working. Now it plain doesn't work. And I can't access router or modem with it.
Message edited by brunch on 08-03-2007 at 08:01:02 AM
Sponsored Links
Are you sure that you have the right drivers. If that doesn't solve the problem, check your ip setting again. Or consider getting a new mobo, because the ethernet may be defective n your current board.
Reply to suvayanr
Tom's Hardware > Forum > General Networking > Network General Discussions > Bewildering Network Problem
There are 466 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
