Recently, I built my own computer. It is only the second time that I have done so, and the last time was 8 years prior.
Needless to say it gave me a wide array of problems, but I ironed them out. Or so I thought.
I got, from what I understand, a fairly serious blue screen error (Kernel_stack_page, I forget the exact wording, but I'm sure anyone familiar with it will immediately know what I am talking about). I was concerned about this, delved into a couple forums, including this one, and asked several friends who are in the computer business. While they all agreed this could be a bad omen, I was told that if it didn't come up again, to just ignore it and go about my business. So I did. 2 weeks later, the kernel error came up again. I was told that problems with my hard drives could be the issue, and sure enough chkdsk, found and corrected errors when I ran it.
A little more then a week later, boom, blue screen again. Still, not so jarring that I was distressed, but I ran chkdsk again, and kept going. Then the blue screen became more frequent, and another memory dump error started coming up at times as well. The computer began freezing all together at times. Eventually it reached the point where the computer could scarcely run for 2-3 hours without crashing. Obviously I knew I had to start trying to narrow down the root cause.
So, here is what I know about the situation in shorthand:
Hardware definitely NOT causing problems:
1. Sound Card
2. Network Card
3. Video Card
4. RAM (checked with multiple programs under multiple conditions)
Potential and likely culprits:
1. Hard drive (s)
2. Motherboard
3. Processor
4. Software (unlikely)
Things I have tried and their effects thus far, or just notable conditions:
1. Crash seems to be accelerated when running Emule, which frequently moves files around on D (storage) drive. Download queues are frequently lost when these crashes occur. Note that while Emule runs off the C (boot) drive, all the files it handles are on the D drive.
2. Crash will occur without emule running.
3. Disconnected D (storage) drive and computer ran for 22 hours consecutively, with several hours of heavy use. No crash.
4. Have now reconnected D drive and am running without emule functioning. So far 6 hours with no crash, but limited use.
5. Just incase it will be asked: Yes I have updated my bios and SATA drivers.
So here is the jist of my question. Would a hard drive failing cause crashes similar to this? Has anyone else experienced something similar with their systems?
1. Sound Card
2. Network Card
3. Video Card
1. Hard drive (s)
2. Motherboard
3. Processor
