audio problem
Forum Windows Vista : Configuration & Customize - audio problem
Hello, i need some help with a really weird situation. I just bought an asus maximus II formula board, everything cool... but when i turn off the pc for a few hours, and start ..... no sound... if i boot, sound comes back. If i turn off the pc for like 30 minutes, and start , i have sound. I have tried remove, reinstall drivers, use vista drivers... asus drivers, even bios upgrade, and no solution.
I have to mention too, when i go to device manager and set uninstall driver, to complete i have to boot.... and when i do it.... i have sound , even when vista said, new hardware found and is installing drivers.
Ill apreciate any help,
thanks
Sponsored Links
i forgot to specify , im running vista ultimate 64 and in the device manager at sound, video, game controllers i have high definition audio device twice... if i disable one of them i still have audio.... its seems like a ghost audio card there.....
Message edited by Overclock Addict on 11-07-2008 at 10:49:27 AM
Reply to Overclock Addict
- 0 +
Well this is probably what you don't want to hear I have an ASUS Crosshair II Formula and the soundcard was aa ASUS PCIE1 Supreme FX II soundcard, problems from day 1 with it, when it was working the sound volume was so low it was like the reproduction was in a tunnel.
Replaced it with a Creative X-FI Extreme Gamer Fatal1ty Pro PCI, using Creatives new Vista Alchemy Drivers, and its awesome, got my sound back.
I doubt you'll get this resolved, maybe through ASUS, but just the same good luck, IMO replacing the soundcard is going to be your best option, my Supreme FX II, now sits on the shelf, useless!
------------------------------ Badges? We don't need no stinkin' badges!
Reply to 4ryan6
My Asus board messes up sound and it is not Vista because XP 32 does it too. If I do a full power down and boot I am fine but if I do a restart my sound is all messed up and stutters and breaks up if I do anything else, games are unplayable.
Happens with both my Creative cards and one of them is a brand new X-fi extreme gamer with Alchemy installed AND it happens with my on-board sound - go figure - maybe it's an old fashioned resource conflict or something. I wish I knew.
It may have something to do with filling all four ram slots or enabling memory remapping. I can't remember if I had it before I did that but I don't think I did.
------------------------------ tehhardpro wrote :
notherdude u have an old hand. Having an old hand doesnt make sence. Cuz its old. get a new one.. seems like ur hand doesnt understand what it is writing. So placve it in ur rig instead of vista human orgnoids will amke more sense
Reply to notherdude
Thanks for your anwers, if i find a solution ill post it. By the way 4ryan6, i was considering doing same as you, but i want to be sure whats my problem. About the 2 audio cards, i was checking and the second one is from my ati radeon 4870x2 video card. I checked and for some reason like i told you when i leave the pc off for a few hours, then at start the only audio card the system found is the one related to the video card.
- 0 +
Well thats weird??????????????, does the 4870X2 have VIVO capability?
Belay that ////////////////// I didn't realize the 4870X2 had its own audio, that could create some definite ghosting issues if you also have another soundcard!
Interesting problem you have, cannot advise as yet I'm researching this one, let you know what I find.
Message edited by 4ryan6 on 11-09-2008 at 02:11:23 AM
Reply to 4ryan6
Thanks man.... i believe the 4870x2 uses that, for the HMDI output.... so u can have high quality video and audio.
Message edited by Overclock Addict on 11-09-2008 at 02:42:52 AM
- 0 +
Check this link all the way to the bottom, and see if it helps you out.
http://www.hardwareanalysis.com/content/topic/72382/
Reply to 4ryan6
Thanks for the help 4ryan6, i fixed the problem. I went to asus, and download the latest vista 64 audio driver for my board, and done! everything running great.
- 0 +
Man thats fantastic, I know this kind of problem can drive you up a wall, maybe your thread will help someone else if others with the 4870 X2 run into this situation.
Reply to 4ryan6
:) U welcome ... nice tu meet you.
- 0 +
Same Same
Have a great day! Ryan
Reply to 4ryan6
Tom's Hardware > Forum > Windows Vista > Configuration & Customize > audio problem
There are 674 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
