Ok i think i'm posting this in the right spot. I have fax server running on sever 2003. It was working ok, but i had the bright idea of having a server that would handle all of the office telecommunications/voicemail/email etc. I uninstalled fax server on the server computer, and tried to get the telecommunications server to work, but unfortunately it wasn't working properly and requires significant more tweaking. I reinstalled fax services on the original server, and works fine on the server, but now the fax console on all of the workstations don't show the received or sent faxes. All the workstations use windows xp. I can't figure out what the issue is, cause it was working fine before, and i reset it up exactly the same way as before. I can send faxes with no problem from any of the stations.
