Question 1: "I recently purchased a JVC camcorder that records video as .MOD files. I can't seem to edit the files or play them on my PC. Is there a way to convert .MOD files to .MPG or something that works on my computer?"
Question 2: I have a video file off my JVC as well and wonted to play it on WMP so i changed the file extension from .MOD to .MPEG. Now the problem i have is that the video quality is poor. It?ˉs like the video cant keep up with the playing speed, lines drag when something moves. I know this quality is poor because it plays fine on cyberlink power dvd. Any help plz on how to fix the poor quality????
Question 3: I change the ext. mod to avi or mpg , and it works but the problem no sound at all.. .try to burn it into dvd, no luck, i try to burn it into vcd no luck also...
Introduction: .MOD files are JVC's implementation of MPEG-2 transport streams, similar to a VOB file on a DVD or the M2T files used on Sony hard drive camcorders.
Solution: I actually just found a program called Aiseesoft Mod Video Converter. This program will allow you to export your video(s) as .AVI,WMV,MP4,3GP files etc. Here?ˉs a brief overview of how to do it:
1. Install and run Aiseesoft Mod Video Converter 2. Add files
3. Set output video format
4. Click the ?°Start?± button to start the conversion.
This tool also allows you to split,join,crop Mod/Tod files, it is very powerful.
I hope this helps, if anyone has a better method or a better software for doing this, please let me know!
Share: a kind of software can both rip DVD and convert video to any video/audio formats
As one of mobile devices fans, I was looking for a valuable all-in-one converter that can both rip DVD and convert video. Recently my friend recommend me the Best DVD Converter Suite — Aiseesoft DVD Converter Suite that can meet my needs. Now I will share with you.
Aiseesoft DVD Converter Suite supports almost all the portable devices, such as: PSP, iPod Classic, iPod Touch, iPod Nano, iPhone (3G), iPhone, Zune, Zune 2, Blackberry, Nokia, Creative Zen, Sony Walkman, iRiver PMP, Archos, PS3, Apple TV, Xbox, iPAQ, Pocket PC, Mobile Phone, etc. You can enjoy your favorite DVD and video files on them.
Key Functions
1. Convert DVD and any video/audio to the various video/audio formats
Aiseesoft DVD Converter Suite software could easily convert DVD and any video to the various video/audio formats such as MP4, H.264, AVI, MP3, WMV, WMA, FLV, MKV, MPEG-1, MPEG-2, 3GP, 3GPP, VOB, DivX, Mov, RM, RMVB, M4A, AAC, WAV, etc.
2. Support almost all popular portable players
Aiseesoft DVD Converter Suite software can convert DVD and video to all the popular devices: PSP, iPod Classic, iPod Touch, iPod Nano, iPhone (3G), iPhone, Zune, Zune 2, Blackberry, Nokia, Creative Zen, Sony Walkman, iRiver PMP, Archos, PS3, Apple TV, Xbox, iPAQ, Pocket PC, Mobile Phone, etc.
3. Easy and powerful editing function (Merge, Trim, Crop)
Aiseesoft DVD Converter Suite software offers powerful editing functions such as merging multiple DVD chapters, titles or different videos files into one file, trimming any clip of video or DVD, cropping video size and so forth.
4. Easy to use
Aiseesoft DVD Converter Suite is very user-friendly and easy to use. Only a few clicks to complete the conversion with supervising the whole process on real time.
Key Features
1. Merge multiple DVD chapters, titles or different videos files into one file
Aiseesoft DVD Converter Suite software provides an easy way to combine and join multiple DVD chapters, titles or different videos files into one file. Just select the DVD chapters, titles or videos you want to join and check the “merge into one file” check box you can finish it easily.
2. Cut any clip of video (Trim)
Aiseesoft DVD Converter Suite software provides “Trim” function to help you cut any clip from the original video. You can set the “Start Time” and “End Time” of the clip you want to get or just drag the slide bar to the accurate position to achieve it.
3. Crop Video Size
Aiseesoft DVD Converter Suite software allows you to remove black edge of your movie and get any playing area of the video by using its “Crop” function. You can also select the “Zoom” mode to extrude your video slightly to adjust to your portable devices so you can get the best video quality.
4. Capture your favorite image
If you like the current image of the video you can use the “Snapshot” option. Just click the “Snapshot” button the image will be saved and you can click the “Open” button next to “Snapshot” button to open your picture.
5. Support Preview
You can preview the source video and edited video.
6. All Encoders and Decoders are built in
Full support all popular video and audio formats.
7. Fastest Conversion Speed
Provide the fastest conversion speed (>300%), completely support dual core CPU.
A lot of people searched dvd video converter on the internet . DVD Video Converter can solve some problem, the main function is to convert DVD to MP4, AVI, MPEG, WMV, 3GP, MP3, WMA etc.
A dvd converter for video fans is not enough. So, a dvd suite is the best choice. I found 4Videosoft DVD Converter Suite.
It is the combination of DVD Ripper Platinum and Video Converter Platinum software. It can convert DVD to MP4, convert DVD movie to MPEG, MOV, 3GP, MP3 etc with super fastest DVD conversion speed. Also, It is easy to convert videos between MPG, MPEG, MPEG2, VOB, MP4, M4V, RM, RMVB, WMV, etc and extract audio from these video.
Key Functions 1.Convert DVD movie to video/audio Powerful DVD Converter to convert DVD movie to MP4, AVI, MPEG, WMV, 3GP, MP3, WMA etc by DVD Ripper Platinum.
2.Convert video files to any other format you want Versatile video file converter to convert videos between MPG, MPEG, MPEG2, VOB, MP4, M4V, RM, RMVB, WMV, etc and extract audio from these video by Video Converter Platinum.
3.Merge, trim, crop – multifunctional editing functions Merge several files into one for your successive enjoyment, get any time length segments from your DVD movie or video files, crop the DVD movie or video files play region and adjust the output aspect ratio with the help of 4Videosoft DVD Converter Suite.
4.Customize output video files. Adjust the DVD movie Brightness, Contrast, Saturation, and Volume. Set the video Encoder, Resolution, Frame Rate and Video Bitrate by using the DVD Converter Suite.
