Building up a new box which consists of the following:
-Gigabyte GA-965P-DS3P
-Intel E6420
-Transcend DDR2 800 1GB RAM x2
-Western Digital 320GB SATA HD x2
-Samsung 18x DVD-RW x2
-ECS 8800GTS 640MB
-CoolerMaster iGreen 600W PSU
-CoolerMaster Cavalier T-01
Anyway I have connected all the correct cables in the right location (as per manual) and have connected the 24Pin ATX Power Connector + ATX 12V (2x2 Pin) Power Connector to the motherboard.
HOWEVER... When I turn on the PC it instantly shuts down and the "red light" turns on the back of the PSU.
CoolerMaster say that this light means either: Over-Voltage, Under-Voltage, Over-Temp, Over-Current, Over-Loading or Short-Circuit.
I have tried changing from the ATX 12 (2x2 Pin) to the (2x4 Pin) Power Connector and nothing has changed.
I did try unplugging power from the standard case fans + DVD drives + 1 Hard Drive and the PC turned on but didnt display any picture and the CPU fan didnt seem to turn on straight away - So I quickly turned off the PC.
I also have a PCIE_12V Power Connector on the motherboard. Should I be connecting the 2x Power Cables from the 8800GTS to this instead of the conventional power cables?? Only reason I havnt is that the Gigabyte manual says to connect vid card to this connector when using "two graphics cards".
Can someone please help me as I desperately need this PC up and running within 2 days.
Thanks
-Intel E6420
-ECS 8800GTS 640MB
Thanks
