I have a dlink wireless router 108.11g, does nething interfere with the reception such as tvs or something, becauyse often my wireless connection just drops out for about 10mins then comes bak on its very weird, does nebody have ne help? and yes i do have a enciption a 20 letter one so noone is hacking in if thats wat u think
Cheers Deathmunky
Sponsored Links
WAT im only tryin to lear :'( ure saddd HELP ME!
Reply to DeathMunky
2.4 GHz cordless phones can interfere with wireless routers. Try a different channel on the router.
Grumpy
Reply to Grumpy9117
Microwaves too.
Reply to brw02005
before you change channels on the router you should check to see that no one else is on the new channel.
Reply to kevofportland1
Tom's Hardware > Forum > Wireless Networking > Range & connectivity > NEED HELP!
There are 1308 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
