News
Next ATI card may have 512 MByte memory
The Inquirer speculates about an unveiling of a new X850 card that will pack twice the memory of its regular version. Read more
Core i7 Incompatible With Performance DDR3 Memory
Performance DDR3 memory that requires a voltage higher than 1.65V may permanently damage Core i7 CPUs Read more
DRAM report: New Intel chips may boost some DRAM firms
The launch of a new set of Intel chips for notebook computers is expected to drive demand for the next generation of advanced memory chip - DDR2 - and help larger memory chipmakers like Samsung Electronics maintain decent selling prices in what was expected to be a weak second quarter. Read more
Intel Nehalem To Allow Overclocking, Some Processors Will Even Encourage It
Taipei (Taiwan) - Hot on the heels of AMD's overclocking secret , we can reveal that Bloomfield and Lynnfield, key processors of Intel's upcoming Nehalem family, will indeed feature overclocking capabilities for up to 16 CPU cores. Read more
Latest Reviews & Articles
Radeon HD 4830: High-Speed, Cheap CrossFire
AMD recently launched its Radeon 4830 to take on Nvidia's GeForce 9800 GT. With PowerColor and Sapphire flavors in single- and CrossFire-configurations, we pitch the card against factory-overclocked 8800 GTs and see who is left standing. Read more
Acoustically Manage Your Hard Drive
Most modern drives can be set to deliver maximum performance or to operate quietly. We looked at how performance, acoustics, and power requirements change when switching from fast to quiet using Hitachi’s Deskstar 7K1000.B. Read more
Graphics Boosted: 790GX's Side-Port Explored
AMD's 790GX and 780G support onboard memory to help improve the performance of integrated graphics. Is it worth paying a bit extra or is the feature a mere gimmick? Read more
PCI Express & CrossFire: Scaling Explored
Does your aging CrossFire-compatible motherboard have enough PCI Express bandwidth to make a second card worthwhile? We compare every Core 2-based platform in order to find out. Read more
All the Reviews & Articles
  Tom's Hardware Forums » Motherboards & Memory » Memory » Help with overclocking memory
Word :   Username :
Bottom
Author
 Thread : Help with overclocking memory
Profile: stranger
More Information
I just purchased a Gigabyte GA-N680SLI-DQ6 motherboard. It supports DDR2 800. I purchased 1066 Crucial Ballistic Tracer memory 2x1 gigs without fully doing my homework. Since I'm stuck with the memory a friend told me that I needed to change the settings on the motherboard to take better advantage of the 1066 memory. I'm new at this, what settings changes would you recommend? Thanks in advance...
Related Product
Profile: member
More Information
Hi, before you start changing settings, download a program called CPU-Z. Open the program, and switch to the memory tab. If it says 533MHz as the frequency, you're all set, and your memory is already running at DDR2-1066
DDR2 stands for Double Data Rate, in actuality, RAM runs half it's rated speed, but the way it's designed, DDR2 can complete two actions per clock cycle, effectively doubling it's speed.
If the frequency is reported as 400MHz, post back, and we can work from there. It's easier to at least check before we start messing with BIOS settings. And what CPU are you using, and are you overclocking it?
Thanks, hope this helps.
Profile: stranger
More Information
I'm using an Intel Core 2 Extreme QX6700 Kentsfield 2.66GHz 2 x 4MB L2 Cache LGA 775 Processor, I haven't overclocked it yet but was thinking about doing that too.
Right now CPU-Z reports 400...
Thanks for the help so far...
Profile: Forum Veteran
More Information
Read this post regarding memory speed, latency and voltage settings: http://forumz.tomshardware.com/har [...] 81#1249881
Profile: member
More Information
Ok, so your RAM is running at DDR2-800.
First let me say that I'm assuming that the DS3's bios settings are similar to the DQ6's.
So, right now, your default FSB is 266MHz. Your RAM is running at 400MHz. So your FSB:RAM ratio is 2:3. Since you're not OCing, we want to change this ratio to 1:2. Using this new ratio will change the RAM speed to 533MHz, or effectively DDR2-1066.
OK, go into your bios. once at the main screen, press Ctrl+F1. This unlocks some advanced settings we might be dealing with. Proceed into the MIT section of your bios. Gigabyte uses a weird FSB:RAM setting, so I'm not sure what yours should say. But whatever it is you want to change it to four. So the FSB is 266 x 4 =1066, which is what you want.
And nice system!! Quad core :shock: Wow, that's gotta be fast. Just to say overclocking is a different story. You definately want an aftermarket heatsink if you don't have one already have one. But using these settings, you can run you memory up to spec.
Hope this helps.
Profile: stranger
More Information
Thanks much! I have a Zalman Resirator ONE water system, so I most likely try to OC the CPU. From what I've read OCing this type of system is very easy, and produces quite an increase in performance. Assuming I bump the multiplyer up a little or the FSBup, the 1:2 ratio is what I want to stive for? Again, I can't tell you how much I appreciate your taking the time to help me out...
Scott
More Information
I misunderstood the above; this space now intentionally left blank. :)
Profile: member
More Information
Quote :
Actually, most folks here would call that a 1:1 ratio, since the FSB clock rate is 266MHz and the memory bus clock rate is 266MHz. To start with, keeping the 1:1 ratio is a good goal. You can experiment with faster RAM speed/timings later.
:? Hmmm. Hear me out here.
In most normal circumstances, a 1:1 ratio is what you want. (Because most people don't need more than a 400MHz FSB in order to fully OC their CPU. So doubling this gives you only DDR2-800. And any slower FSB speed will require slower RAM. So in most cases, DDR2-800 is overkill for OCing) The only problem I see with that is when you want to run your RAM at full speed. So to run sghill's RAM at full speed, he needs a FSB of 533, which is a substantialOC. Even if he lowers his multiplier, hitting a 533MHz FSB is a difficult feat! So I don't recommend for sghill to try a 533MHz FSB.
So in this case, where RAM speed is higher than a reasonable FSB, you have to change the ratio. I think 1:2 is the best because the RAM is exactly twice as fast as the FSB. Rather than 2:5 and similar ratios. And RAM is normally easy to OC. My DDR2-675 (4.4.4.12) ran DDR2-1066 (5.5.5.15) no problems, or extra voltage. So that's a 60% OC! So I'm sure your RAM can be ran higher than speced. And since you have a Core 2 Extreme, your multiplier is unlocked! So when you OC, I'd use the multiplier to OC rather than the FSB. Lower FSB speeds I think are better because of the less voltage required, and less heat output of the Northbridge.
Hope this helps. And please ask any questions you may have!
More Information
Sorry, I misunderstood your post! When you mentioned a 533MHz RAM speed, I thought you were talking about the effective data rate, not the memory bus clock rate. Thanks for the clarification.
Profile: stranger
More Information
Thx all for your help!
Profile: stranger
More Information
I've finally got the machines monitors, I have three, one 30" Dell and two 20" Samsungs up and running as one.
Now, I'd like to overclock this thing and set the memory to it's full potential. I was thinking about uping the multiplyer to 13 from 10, then increasing the voltage to 1.45. Only problem is I don't know what voltage to turn up..
Which voltage control do you change??? There are several settings on the board,
1. System Voltage Control
2. DDR2 Voltage Control
3. NB/PCIE
4. SB/PCIE
5. FSB Voltage Control
6. HT-Line
7. SB Standby Voltage Control
8. CPU Voltage Control
I'm thinking it's #8 CPU Voltage Control, but don't want to guess.
After I get the multiplyer up and the voltage set, what are your recommendations for the memory as far as the settings to take full advantage of the 1066 speed?
I know this is alot to ask, but if you have a couple of minutes I'd really apprecitate your input, thanks ahead...
Scott
Profile: member
More Information
Quote :
Yeah, just rub it in. :lol:
Ok, if you haven't already, READ THIS.
When the guide mentions a X6800, that also applies to you.
And because of your higher than normal memory speeds, disreguard this:
Quote :
Gigabyte: Set ‘Memory Multiplier’ to 2 (1FSB:1RAM operation)
Instead you want to use a memory multiplier of 4. If you use the standard 2, you will have to set your FSB over 533MHz in order to run DDR2-1066. Becaue this is such a hard thing to do, use a 4 multiplier.
BE WARNED!! If you adjust the FSB with a memory multiplier of 4, You will be overclocking your RAM also!! This isn't bad, I just wanted to point that out.
For you I'd stay away from using the FSB to OC. Since your multiplier is unlocked, I'd just up the multiplier a bit. With stock FSB, a memory multiplier of 4 and a CPU multiplier or 11 or 12, you will have a 2.93 or 3.19GHz CPU and your RAM will be running in spec at DDR2-1066.
And since I just realized you have watercooling, you might even be able to use a 13 multiplier to hit 3.46GHz!! :shock: And that'll be somethin' to brag about!!
So READ THE C2D OC'ing GUIDE and then re-read my post. And if you have any more questions, don't hesitate to ask! I enjoy doing this.
Profile: stranger
More Information
Thanks once again!!!
Profile: stranger
More Information
I increased the multiplier to 12 and increased the voltage to 1.4, when I start the machine and start CPU Z it shows a voltage of 1.36 and a multiplier of 6. The voltage seems to oscilate at the beginning of the startup, then settles down to 1.36.
Also when the machine is starting, the multiplier oscilates between 6 and 12.
Any ideas as to what is happening?
Thanks, Scott
Profile: Faithful Poster
More Information
It might be Intel's speed step ie. your processer clocks itself down when theres no load detected then when your processer detects a load it clocks up to say 3.4GHz if thats you overclock. CPU-Z can show you when it clocks down. Let say you have the Vcore at 1.4, your processer uses slightly less to maitain 1.325volts. Basicly to maitain 1.375 you have to have 1.4 as an overhead. Hope this helps.
Profile: stranger
More Information
It sure does, I was worried my power supply was not providing a steady stream of juice to the board...
Thx...Scott
