IE8 ActiveX Problems
Forum Applications : Internet Applications - IE8 ActiveX Problems
Hello all :)
Ok, I went to check if there were any updates in Windows Updates and for some strange reason, it comes up with a page that says "Internet Explorer has closed this webpage to help protect your computer." Any idea of how to fix this?
FYI - I am running XP and have already tried chaning the security settings. Oh, and this also happened when I went to try and download the latest Nvidia drivers for my video card at Nvidia.com.
Thanks in advance! :D
------------------------------ OS: XP SP3. CPU: AMD Athlon 64 3000+. Mobo: VIA k8m800, socket 754. Ram: 1gb PC2100 (133mhz). Video card: Nvidia GeForce 6200. Sound Card: Diamond Xtreme 5.1. PSU: A Power Golden Deluxe 580W.
And THAT is the reason I am wanting to get a new computer ;)
Sponsored Links
Congifure the security preferences of IE 8. Go to, tools, properties, security, and select medium-high. Re-start IE8 and try....
Or a better option, unistall IE8 and leave IE7, or use Firefox...Opera...Safari...
------------------------------ If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
IE8 has had some issues. I 2nd the suggestions of saint19.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
I would kinda sorta like to stick with IE8 if I can find a solution..... but if not I guess I will have to revert back to the previous version.
Oh, and @saint19:
I already did try the security settings, but thanks for the response :)
You too, aford10
Reply to ElectroGoofy
Does the behavior persist in No Add-ons mode?
This post from the IE Blog will instruct you about troubleshooting Internet Explorer with Add-ons disabled - http://blogs.msdn.com/ie/archive/2 [...] 78113.aspx
Also, this guide to solving IE 8 crashes could prove useful - http://support.microsoft.com/gp/pc_ie_intro
These might help you as well:
How to troubleshoot Internet Explorer issues in Windows Vista and in Windows XP - http://support.microsoft.com/kb/936215
How to optimize Internet Explorer - http://support.microsoft.com/kb/936213
I hope at least some of this info helps,
- Jake
MSFT Internet Explorer Outreach Team
Reply to jake_ie8team
IE has many issues, for windows update I think it should be automatically shown in your desktop status right?
You could opt to change your browser to Firefox or Chrome, I am pretty happy with its performance. You can use IE as your secondary browser.
Reply to rodyhoffer
Ok, just tryed Windows update and for some reason it works now. Nvidia auto-card-detect still not working, but just did the manual choose and download..... thanks for the responses! :D
Tom's Hardware > Forum > Applications > Internet Applications > IE8 ActiveX Problems
There are 1083 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
