Tom's Hardware Forums » Wireless Networking » Range & connectivity » Wifi problems on laptop
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Wifi problems on laptop
Profile: stranger
More Information
Hi.
I have a problem. I am trying to connect to a Wireless network in my work, but i am not able to do so with my laptop. The problem is i can't see the network. It is not available under show available network even if i insert the SSID of the network. I can connect to the network through my PSP console and the signal is 95%, but when i try to connect with my laptop it is not detecting a signal. I have the latest drivers. When i run ipconfig it says that i am not connected to the wireless network. I am helpless
Related Pr oduct
Profile: enthusiast
More Information
What encryption you using. You may want to initially shut it off to get it workiing. Also check dhcp settings
Message edited by brw02005 on 09-21-2007 at 05:32:58 PM
Profile: stranger
More Information
There is no encription on the network, it's a company wireless internet. DHCP settings are automatic and it should be correct. Still not working
Profile: enthusiast
More Information
Yeah I got nothing check for adware or run an ubuntu live cd if your wireless card supports linux to see if it's just a hardware problem or windows settings being messed up.
Add a reply
Google Ads
