Tom's Hardware > Forum > Windows Vista > Vista General Discussion > PCI-BUS MEMORY RANGE CONFLICT HELP!!!! ME!!!
Forum Windows Vista : Vista General Discussion - PCI-BUS MEMORY RANGE CONFLICT HELP!!!! ME!!!
PCI-BUS (in the proberties i have got this - Conflicting Device List -Memory Range DFF00000 - FEBFFFF not available
Now i want to correct this , i check all the rest and this seems to be the outcome now what i want to know is how to fix it, i was thinking that the only card in my pci bus atm = my sitecom wireless pci card - tho i am using a usb wireless device atm until my new net arrives (which hopefully i just use the Gigabyte lan port^^) as most wireless routers nowadays have eternet @ the bk of them also.
So can i just disable this PCI-BUS or can someone explain to me how to fix as im into overclocking + tweaking windows vista/ win 7 but never in my time have i done anything like this .
I check the verifier for the pci drivers that are installed and running 2 relate to my pci-bus driver. one is called pci.sys and pciide.sys
Any one would like to help a confused elf :bounce:
Sponsored Links
There are 1303 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
