Mu33rto :
whats the output of "sudo wvdial" ? Check "/var/log/messages" look for "pppd"
----The output in terminal when I try to connect by typing wvdial:---
Connect 49333/ARQ/V90/LAPM/V42BIS
Carrier detected, waiting for prompt.
CVX Access Switch.
Access is restricted to authorized users only.
Login:
-Looks like a login prompt
-sending: guest
Guest
Password:
-Looks like a password prompt.
-Sending: (password)
-Valid commands are:
-Quit: hang up and disconnect
-Help List valid commands
Hmm..a prompt. Sending “ppp”
Ppp
‘ppp’ is not a valid command.
Valid commands are:
Quit: Hang up and disconnect
Help list valid commands
[this recurs 2 more times, then:]
Don’t know3 what to do! Starting pppd and hoping for the best.
Starting pppd at Mon Apr 9 08:09:09 2012-04-09 Warning: Could not modify /etc/ppp/pap-secrets: Permission denied
PAP (Password Authentication Protocol) may be flaky.
Warning: Could not modify /etc/ppp/chap-secrets: Permission denied.
CHAP (Challenge Handshake) may be flaky.
Pid of pppd: 2228
Using interface ppp0
Pppd: [symbols]
Pppd: [symbols]
Pppd: [symbols]
Pppd: [symbols]
Pppd: [symbols]
Disconnecting
The PPP daemon has died: A modem hung up the phone (exit code=16)
------Here's from /var/log/messages file:------
Ppp 2.4.5 started by tyler-9, uid 1000
Connect: ppp0<-->/dev/ttyACMO
LCP: timeout sending config-Requests
Connection terminated
Modem hangup
Exit
AND:
----Also in /var/log, I also checked the messages1 file------
Here’s the message1 output from last week when I *was* connecting as normal:
[I “x’d” out the actual numbers in addresses]
Pppd 2.4.5 started by tyler-9, uid1000
Connect: ppp0>/dev/ttyACMO
Local IP address xx.xx.xx.xxx
Remote IP address xx.xx.xx.x
Primary DNS address xx.xx.xx.xx
Secondary DNS address xx.xx.xxx.xx
CCP: timeout sending Config-Requests
So comparing the above outputs fr/messages vs message1 files: In messages, it says “ppp 2.4.5 started” but in messages1 it’s “pppd 2.4.5”—could this difference explain the problem?
Thanks for help!
