Tom's Hardware > Forum > Windows XP > Configuration & Customize > Wireless Connection issues, SP1
I just had to format my drive/set up a new boot disc, and setting up internet is a major pain. I'm using a linksys wireless-G adapter to connect to a home network on another computer (this one) - I install the drivers, and create a connection..
Windows has a popup saying wireless networks are available at the bottom right of the desktop, so I open that and try to connect, but at the same time it says "Wireless Connection Unavailable" on network connections beside the network I created and has a red X on the right side of the icon. The wireless connection's icon also as a black Y shape symbol on it which I've never seen.
I didn't have this issue with SP2, so appears to have something to do with that - I'm using an original disc, which I think is SP1.
When I attempt to connect to a network (typing out a password like 40 characters long, twice) it just closes the wireless network window and does nothing.
Sponsored Links
http://www.microsoft.com/windowsxp [...] eless.mspx
Foudn that, which mentions SP2 makes setting up a wireless connection much easier..unfortunately it says nothing about how it's done on SP1/original.
Reply to ArchosSecutor
There are 833 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
