Nvidia is expected to launch its 90nm GeForce 7900 graphics processor unit (GPU), in GT and GTX versions, on March 9, according to sources at Taiwan graphics-card makers. Read more
Sub-$200 Nvidia Geforce 7900 GS-based graphics cards are expected to appear in the channel market from August 30, targeted to compete with the ATI Radeon X1650XT series, according to sources at Taiwan-based graphics card makers. Read more
Nvidia will launch upgraded versions of the GeForce 7900 GTX and GeForce 7900 GT graphics cards that support HDCP (High-bandwidth Digital Content Protection) between July and the middle of August, with the cards continuing to be manufactured by Flextronics, according to sources at Taiwan graphics card makers. Read more
Nvidia updated its graphics chip portfolio with the new mainstream chip 7900 GS, which will be available in graphic cards selling between $200 and $250. The 7950 GT will follow next week and aim for the hardcore PC gamer and a prices between $300 and $350. A handful of companies have already pledged availability of the GPUs in their latest graphics cards. Read more
Do you remember the stereo glasses that were around about 10 years ago? Now that 120 Hz LCDs are starting to pop up, Nvidia is teaching an old dog some new tricks with its GeForce 3D Vision shades. Read more
Can AMD finally recapture its former market lead with the Phenom II? We tested their new 45-nm CPU, which is compatible with AM2 motherboards. How do things look from performance, energy consumption and overclocking perspectives? Read more
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
| Bottom | |
| Author |
Thread : Geforce 7900 GT problems
Profile: stranger
More Information
Im not exactly sure whats wrong with my computer, but it randomly shuts down and has trouble running any 3d games. I recently updated all my drivers for my gfx card and it still has the problem. Driveragent says that alot of my drivers are out of date, but i dont know exaclty what drivers i need to update and where to get them =X. Right now my 2nd moniter on the left side is shutting off and on randomly in odd intervals. Alot of the time i have trouble moving things from one screen to the next, and it can sometimes cause the computer to restart or lag out badly.
Related Product
Profile: Eternal Poster
More Information
You will need a lefthanded metric screwdriver to fix it.
Profile: stranger
More Information
The 500w PSU that came with my case... Could that be the problem? And the drivers i downloaded were from nvidia's websight. |
Monkey wants to steal peaches
Profile: Faithful Poster
More Information
It could well be, or it could just be the supply to the card, does the PSU have a dedicated PCI-e supply? or are you doing the molex thang? and if so what else is running on that rail?. |
Profile: stranger
More Information
Uhh, thats alot of jargon i dont understand =P. I dont have a dedicated line or anything to it, i dont think it has a single cable for the PCI-E card either, the card requires two connectors to it tho.
More Information
O.K, and how are you supplying the power to the card?. |
Profile: stranger
More Information
Well i have two molex that combine into the 4 pin connector that connect into the card. I just redid all my wiring and now the card has its own molex line. And i moved my case out of the cubby hole on my desk. It works better now, still a little laggy here and there, but no crashes so far. |
More Information
That should be a 6 pin connector into the card, please check that because if it is a 4 pin the the card is not getting enough power. |
Profile: stranger
More Information
Whatever pin it is its the cable that came with the card, it must be a 6 pin then. |
More Information
Then I suspect that the generic 500w PSU that came with the case may be giving up the fight, do you have a spare one that you could try?. |
Profile: stranger
More Information
mousemonkey, I am having the same problems as Mstngdrew232. Same card, same symptoms.
Profile: stranger
More Information
I think this card runs a little warm or something in our systems are running a little warm. Try putting a new VGA cooler on it or some more case fans, i moved my case out into some free flowing air and it helped cool it down alot. I still have some software compatability issues every now and then, but the computer has stopped crashing completely. |
Profile: stranger
More Information
Running warm, you mean GPU core temperature? Mine runs in the mid 50's which is well within tolerance according to the nvidia control panel (the bars are green until 78 degrees). The ambient temp inside my case is ~30 degrees. All various fans inside function properly. |
