Issue 1:
Well I wanted to mount shares
to a Fedora 17 guest. I succeeded by modifying my /etc/fstab:
But strangely I get this error on boot:
If I press Control-D it works just fine... how strange.
Issue 2:
Multi-monitor in LXDE under Virtualbox.
I get two identical displays (mirror). I want them to display two separate things each. Eg. 1 full screen Firefox + 1 full screen LibreOffice (extended/span mode) rather than both screens showing the same Firefox window.
I'm assuming LXdisplay won't help me here...
FYI: LXdisplay detects them as two separate displays, which is nice because Fedora 15 doesn't, it sees them as one and the same.
So I changed my Xorg.conf from
to
based on this advice:
http://en.gentoo-wiki.com/wiki/X.Org/Dual_Monitors
but got absolutely no response from Fedora.
Do I need to configure Xinerama or something apart from the regular?
Code:
E:/Nexus
E:/Download
Code:
# /etc/fstab
# Created by anaconda on Sat Jun 16 19:29:14 2012
# Accessible filesystems, by reference, are maintained under '/dev/disk'
# See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info
/dev/mapper/vg_katyrvm-lv_root / ext4 defaults 1 1
UUID=1c638e90-e6d7-4fcf-ac85-d415dd8d68fc /boot ext4 defaults 1 2
/dev/mapper/vg_katyrvm-lv_swap swap swap defaults 0 0
Nexus /home/strayfire/Documents/Nexus vboxsf defaults 0 0
Download /home/strayfire/Documents/Download vboxsf defaults 0 0
Issue 2:
Code:
# VirtualBox generated configuration file
# based on /etc/X11/xorg.conf.
Section "Monitor"
Identifier "Monitor[0]"
ModelName "VirtualBox Virtual Output"
VendorName "Oracle Corporation"
EndSection
Section "Device"
BoardName "VirtualBox Graphics"
Driver "vboxvideo"
Identifier "Device[0]"
EndSection
Section "Screen"
SubSection "Display"
Depth 24
EndSubSection
Device "Device[0]"
Identifier "Screen[0]"
Monitor "Monitor[0]"
EndSection
to
Code:
Section "Monitor"
Option "Primary" "false"
EndSection
Section "Monitor"
Identifier "Monitor[1]"
Option "Right" "Monitor[0]"
Option "Primary" "False"
EndSection
Section "Device"
Driver "vboxvideo"
EndSection
Section "Screen"
Depth 24
Modes "1920x1080"
Virtual 3840 1080
EndSubSection
Device "Device[0]"
EndSection
