Major problems
Forum Windows XP : Configuration & Customize - Major problems
I have been attacked by a virus which has created some major problems on my computer which I cannot remove. Here are the problems that I aam having:
Try to open desktop ICONS and I get a message that "this file doesn not have a program associated with it for performing this action. Create an association in the fil options control panel" I get this on every program I try to open an then I have to right click on the program got to "run with" and then unprotect my computer for the program to open.
Also my computer cannot open file rundll32.exe. Last I have "backoor.???" trojan virus which is continuously picked up by my default virus scan but after reboot is not removed..
I have used the follwonig programs to try and correct the problem:
Spybot / ad-aware7.0/ Yahoo tool bar anti-spy/ registry mechanic6.0/
I also ran in dos the sfc/scannow option. I am out of ideas!!!! please help!
Danny
Sponsored Links
insert windows installation disk, reboot machine, select boot from cd in bios, save and exit, boot from cd - format and run a clean install of windows.
you could try running grisofts free avg virus scanner, but i get the feeling your virus is blocking most things from running.
Reply to montyuk
Tom's Hardware > Forum > Windows XP > Configuration & Customize > Major problems
There are 741 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
