SMSC today announced at the IDF a range of new components aimed fro the digital home and office. Read more
If you carry around lots of data, you may as well do it in style. Kanguru announced a redesigned external harddrive series in alloy casing and blue lighting effects. The capacity of the "Quicksilver" drives ranges from 80 to 400 GByte. Read more
Oxford Semiconductor claims to be the first company to offer a SATA interfacing bridge chip to external storage manufacturers. Read more
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
Tom's Hardware Forums »
Motherboards & Memory
MSI-Microstar »
First and last MSI M/B I'll buy (USB2/IDE problems)
| Bottom | |
| Author |
Thread : First and last MSI M/B I'll buy (USB2/IDE problems)
MSI-Microstar »
