Hey all,
I've got a quick question regarding RAM speed and it's effect on game performance.
I've got 2 gb of PC3200 (DDR400). It's in the configuration of 2x512 chips of Corsair, with a CAS of 2.5, and then 2x512 chips of Patriot, with a CAS of 2.0. I'm running these on an ASUS P4P800SE Motherboard with a Intel Pentium 4 3.2 ghz processor with an 800mhz FSB.
When my computer boots up though, it proclaims "DDR Frequency: 266mhz, operating in Single-Channel mode or Virtual Single-Channel mode".
Now I'm guessing that that display should either be displaying 400mhz or 800mhz, right? Can you not mix latencies like that? Each DDR memory bank channel is populated with its identical counter-part...
Now say that these two RAM types ARE incompatible for Dual-channel mode. Would it be an advantage, strictly with games in mind, to remove a gig and run it so that it IS running in Dual-channel, or should I keep it with 2gb even with the slower frequency?
Thanks!
Sam
Thanks!
Sam
